Old 03-04-2016, 06:01 PM   #1
Disconnect TT battery when on shore power?
I just recently got my second Wildwood TT. I always disconnected the battery before plugging into shore power. The placement of the battery on the new TT makes it difficult to disconnect the power. Would it harm the battery or cause some problems if I left it in line?
RitaB is offline   Reply With Quote
Old 03-04-2016, 06:07 PM   #2
Why did you disconnect the battery? When you're on shore power, the shore power supplies the converter, which charges the battery. Disconnect the battery = NO battery charging.
Don't disconnect the battery.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 03-04-2016, 06:13 PM   #3
Herk7769's Avatar
New 3 stage chargers are designed to be connected safely always.
Enjoy you camper and don't worry about your battery. (check the water level at start and end of season. Fill ONLY to the fill ring inside the cap if needed - no more).
HAM CALLSIGN - KC3FFW
Old 03-04-2016, 07:09 PM   #4
bikendan's Avatar
Why would you disconnect the battery when you hook up to shore power?
Your converter should be 3 stage and should be fine in keeping the battery charged.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-04-2016, 07:39 PM   #5
One of the purposes the battery serves is as a huge filter capacitor. The battery can minimize voltage spikes. It cannot do that if its not connected. I never disconnect my batteries unless I'm working on the 12 volt circuitry or replacing the batteries....which is kind of the same thing. You can feel comfortable leaving the batteries connected as you are plugging and unplugging the shore power.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 03-04-2016, 08:04 PM   #6
Blackhat6mike's Avatar
Never heard of anyone disconnecting their batteries from the converter when on shore power. Am I missing something here?
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 03-05-2016, 12:44 PM   #7
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
RitaB,,,,I had the same question 12 years ago when I was a newbie......your converter knows what to do. Don't unplug the battery. And it doesn't matter how long you do it either.
Grampa Jim is offline   Reply With Quote
Old 03-05-2016, 02:28 PM   #8
On the old trailer like 1980`s, the converter somme time would charge the battery until the acid dried out.
That`s why then, I was leaving the converter on the battery for a day or tow and I was disconnecting.
The new 3 steps converter will not damage your battery anymore, it will maintain
the battery full charge only.
Jonol is offline   Reply With Quote
Old 03-05-2016, 05:54 PM   #9
txkreddog
txkreddog's Avatar
We leave the battery hooked up during the camping season, and keep a check on the water level. Leaving it hooked up should cause no problems. Since the battery on our unit powers the brakes in the event of TT separation from the TV, leaving it hooked up prevents forgetting to hook it up, if all that makes sense.
txkreddog is offline   Reply With Quote
Old 03-06-2016, 10:48 AM   #10
Boots49's Avatar
Send a message via Skype™ to Boots49
Herk, I have a Wildcat 2009, do you know if the converter/charger would be a 3 stage, it is in storage, so I cannot check the model on the service panel?
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
Boots49 is offline   Reply With Quote
battery, power
