Old 11-18-2017, 10:06 PM   #1
thepricefamily's Avatar
Dometic Rear A/C-Heat Unit
We have a Wildwood, 36 foot. There is a rear unit where the bunk beds are. A/C works great but there is an option for heat. However, it’s not blowing hot air. Any suggestions?
thepricefamily is offline   Reply With Quote
Old 11-19-2017, 06:37 AM   #2
There may be an option for heat but it must have a heat strip to produce heat. If trailer is new, request the spec sheet which shows everything on the trailer. That’s what I did and found out the heat strip was in the front bedroom ac and not the main ac.
Rdeejr is offline   Reply With Quote
Old 11-20-2017, 10:49 AM   #3
VinceU's Avatar
Could be the unit controls are included for a heat pump and it’s not.
Maybe it’s defective and will not port over to heat pump.
Very likely you’re not allowing enough for it to produce heat, they all start out as cool air. Eventually building to warmed air but never hot like a gas furnace.
Unlikely to have heat strips, the most expensive heat of all.
Old 11-20-2017, 11:27 AM   #4
I have a Dometic Duo Therm and the heater is no longer blowing hot air. It has in the past. 2013 Sunseeker. Any suggestions?
crcorn is offline   Reply With Quote
Old 11-20-2017, 01:06 PM   #5
Just as confused as you
Scrapper's Avatar
If you have a heat pump model, they don't work below 40*F.
Richard & Jill
Old 11-20-2017, 02:48 PM   #6
New:
compman69's Avatar
On my Georgetown, I have front AC with heat strip and rear AC has heat pump?!
The front blows luke warm air with heat strip. The rear is the same just slightly warmer with the heat pump. They have both at one time or another quit working. When I took it in for service they found the front had a loose connection and the rear controller box was bad.
I find the furnaces works better and seem pretty efficient in heating up the RV. I hope you find your answer as to whether it has heat or if it is even hooked up on installed?
2017 Days Camping = 5 soon to be 12!
2016 Days Camping = 38
2015 Days Camping = 48
New: 2015 Forest River Georgetown 328TS
2016 Equinox Tow Vehicle
old: 2013 FR Rockwood 2318G w/ 2001 Ford F250 4X4 Diesel
compman69 is offline   Reply With Quote
Old 11-20-2017, 03:56 PM   #7
VinceU's Avatar
If it once worked and is close to 5 years old and not working I’d suggest a good electric heater for the floor. Same current draw and also cheaper than the roof heat pump repair.
Old 11-20-2017, 07:50 PM   #8
It did not work at 50f
Old 11-20-2017, 07:56 PM   #9
VinceU's Avatar
It’s no longer a heater when you need it! Is it worth troubleshooting st $100/hour? Your call, see post 7.
Old 11-20-2017, 08:02 PM   #10
I did buy a small heater. I just do not like things not working. Will not worry about it. Thanks
Old 11-25-2017, 06:58 PM   #11
Bene Gesserit Rule
Murbella7's Avatar
Most Dometic A/C's use a heater, not a heat pump (which is essentially a reverse cycle aircon). Heat pump models are much bigger and heavier.
Murbella7 is offline   Reply With Quote
Old 11-25-2017, 08:02 PM   #12
Retired JSO's Avatar
The dometic ac’s and Heat pumps are basically the same size.
Retired JSO is offline   Reply With Quote
