Old 09-07-2019, 02:51 PM   #1
Door and Awning
Can you have you front door open and latched and the awing down/open at the same time? Looks like it is open the door and not the awing or put the awing out and leave the door closed????
Mike Gray
Forest River Wildwood
2018 230BHXL
2015 Sierra SLE 5.3 V8 4x4
Mike223 is offline   Reply With Quote
Old 09-07-2019, 03:33 PM   #2
WOW!
What a poor design.
Days Camped: '17=30 '18=51 '19=58 '20=14
Old 09-08-2019, 01:33 AM   #3
Hekdog's Avatar
It looks like someone replaced the center plastic piece with the t hook on it with the 3 inch version. You should have a 6 inch which will keep the door much closer to a 90 degree angle to the camper and allow you to have the door open with the awning out.
I would suggest keeping some extra on hand since it's only a matter of time before you forget its hooked up and go to shut the door and break it. This is probably why yours has the wrong one on it.
Here is a link to one of many options.
RV Designer E236, Plastic Door Holder, T Style, 6 inch, Black Entry Door Hardware https://www.amazon.com/dp/B002UC8OUY..._ObkDDb968MRAA
Scott H.
2016 Wildwood X-Lite 230BHXL
2011 F150 FX4 Ecoboost
Fargo, ND
Hekdog is offline   Reply With Quote
Old 09-08-2019, 06:40 AM   #4
Thanks Hekdog you are right. I ordered one just now. Wait and see if that works.
Mike
Mike Gray
2018 230BHXL
door
