09-17-2015, 11:23 AM
Electric stabilizers
So we have taken our trailer on 7 trips this summer and have really enjoyed ourselves. I am finding a bit of dislike towards the electric stabilizer jacks on this trailer. With the jacks down I still notice a lot of movement to the trailer. almost no different then with the jacks up it seems. I also had a recent issue where a pin for the jacks came out causing them to not retract on the worm gear. Luckily I found a cotter pin in my tool bag and was able to get them retracted so we could leave.
2015 FR Wildwood X-Lite 262BHXL
2007 F250 4wd CC SB 6.0 Diesel
09-17-2015, 11:33 AM
I like them. I first find out where level front to back is, then I drop the nose and deploy the rear electric jacks until they are snug. Then I raise the nose a little above level with the tongue Jack, then deploy the front jacks. Then I drop the tongue Jack down until it lifts off of the block. I set the front jacks down to the blocks, then lift the tongue Jack. Solid as a rock.
Bruce
09-17-2015, 11:38 AM
Always Learning
5LowesOR - I do find a difference with them down, but it's not much. Even with triangulating stabilizers back there (initially Ultrafab Eliminators and now SteadyFast)- the improvement is only marginal.
I've got these in my cart to put under to see if they help:
Amazon.com: Husky 70564 Adjustable Stabilizer Jack, (Set of 2): Automotive
09-17-2015, 11:53 AM
I wonder if the actual location of the stabilizers front to back have an effect. for instance on my trailer the rear stabilizer is between the rear door and the rear axle. I would think it would be better farther back on the trailer.
09-17-2015, 12:10 PM
Always Learning
Mine is at the very back of my camper- just ahead of the rear bumper.
09-17-2015, 01:29 PM
Yea I am thinking that rear placement is in a poor location. Since its still under factory warranty I wonder if they would move it at no cost or little cost?
09-17-2015, 01:51 PM
Always Learning
Extremely unlikely. They'll offer to sell you extra stuff to make it more stable.
Learn To RV: Shake, shake, shake - RV Stabilization
09-17-2015, 02:21 PM
Try using xchocks on the wheels it should help considerably with back and forth motion. They worked great for me. I also got a few of those stacking jacks and placed them around the trl including under the stairs.
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
09-23-2015, 12:00 PM
anyone experience the pins falling out causing the stabilizer to not raise/lower
09-23-2015, 12:07 PM
i noticed the same thing, I've added the X between the tires and some other stablizer jacks. After our last trip, I did some 'testing' at home, if I put the OEM stabilizers on a few blocks and have them closer the frame and not fully extended I have less rocking from side to side.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
09-23-2015, 12:10 PM
Mod free 5er
Putting a modified/reinforced set of electric jacks in front of the axles along with the reinforced rear electric jacks, Bal X chocks and homemade JT Strongarms took about 99% of the movement out. Just our experience with the issue. I don't put blocks under any jacks as I like them as close to vertical as the terrain allows.
10-07-2015, 08:08 PM
We bought the x chocks from amazon and they changed everything! No more wobbling when we are in the trailer. We also have the electric stabilizer jacks.
http://www.amazon.com/X-Chock-Wheel-...words=x+chocks
10-07-2015, 09:12 PM
Originally Posted by FRWildwood16
X3
Mike and Brenda
TV - 2013 Silverado 1500, 5.3L
TT - 2012 Wildwood 26 TBSS
10-08-2015, 11:18 AM
i dont seem to feel the trailer moving due to the tires. its more side to side movement almost like the stabilizers just dont hold the weight of the trailer well. I will look into that x chock though as i see those often lately and feel it would be a better wheel chock
10-08-2015, 07:42 PM
We noticed a big difference when we added the x chocks to our front and rear stabilizing electric jacks. Eliminated most of the bounce and wobble.
Salem Hemishere 263RL
2010 Ford F-150, 3.55 Quad Cab
Micanopy, Fl
04-26-2016, 06:56 PM
I get the side to side as well, and i am a big guy, Wife notices more when i go in and out the door, i plan on getting some step stabilizers to see if that helps, i thought about jack stand on frame but LP line for outside grill is run on my door side frame
05-01-2016, 11:00 AM
the step stabilizers did wonders (solved)
