Old 01-19-2017, 08:36 PM   #1
Electric to hydraulic brake conversion
Hello forum folk. I'm seriously thinking about converting the electric brakes on my Wildwood 28RKSS (2017) from electric factory puny brakes to something that actually stops mo better. I've played with the settings on the Tekonsha P3 and I'm at about a 6.3 - Dont get me wrong, it's not bad, but I live in the Raleigh, NC area and we just love that Blue Ridge. Really good brakes are a must have. Does anyone have any experience with disc brakes vs electric? Has anyone done the conversion? (I must be really bored this winter!!)
Sawtooth is offline   Reply With Quote
Old 01-19-2017, 09:12 PM   #2
BessieHunter's Avatar
Have not done a actual conversion but did buy a 5er with disk brakes after owning three other trailers with electric brakes and will not go back to electric again. Absolutely love the disk brakes.
BessieHunter is offline   Reply With Quote
Old 01-19-2017, 09:39 PM   #3
dieselguy's Avatar
I'm just waiting on warmer weather this Spring to swap over to disk brakes on my Silverback. I've bought all the components from 4 different sources to the tune of around $1300 for 6K axles with 6 lug wheels. It will be a few hundred more for 7K axles and or 8 lug wheels. I've done the swap before taking about 1/2 day for the install and another hour to bleed and tune the controller the following morning. The more difficult part is running the lines and making a mount (if needed) for the power unit ... the rest is very straight forward.
dieselguy is offline   Reply With Quote
Old 01-19-2017, 09:58 PM   #4
W5CI's Avatar
From what I have heard there is no comparison in the braking. I am having it put on my CC when it warms up some. Performance Trailer will come to you for install
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
W5CI is offline   Reply With Quote
Old 01-20-2017, 02:28 AM   #5
Hey diesel guy, where did you get the parts? Did you use the GAWR to determine the right units to buy. I'm a little apprehensive about getting the right parts. Not at all shy about doing the work. I may even get to buy some more tools - always a good thing!
Old 01-20-2017, 01:02 PM   #6
bscottroberts's Avatar
My heavy fifthwheel had electric drum brakes and they were horrible. With my brake controller on full, it did not stop like it should. I upgraded to disc and electric over hydraulic. (Did the work myself- not hard.) Night and Day difference!!! I now run my brake controller at around 40% and it stops on a dime. I am very happy with the results. If you have a heavy trailer, then disc with hydraulic is the way to go.
It cost me right under $1500 to do this on 7K axles.
2006 34FK Work and Play
2016 Chevrolet 3500 Duramax DRW
bscottroberts is offline   Reply With Quote
Old 01-20-2017, 02:12 PM   #7
Don
Elec to Hydraulic Disc Brake Conversion
I too would like to convert to disc brakes. Where do you get the parts to do this and how does the emergency brake work. When I had my previous truck with an add on brake controller my elec brakes worked very well and had to keep it set low so the brakes didn't lock up. On my new 2016 Ford F350 I have to run my controller at about 80% to get sufficient braking. Don't know what the difference is.
Sandy12345 is offline   Reply With Quote
Old 01-20-2017, 02:27 PM   #8
BandJCarm's Avatar
Performance Trailer Braking Titan Hydraulic Disc Brake Conversion Kits and Installation
https://www.etrailer.com/question-136671.html
https://www.lci1.com/assets/content/...-brake-web.pdf
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 01-20-2017, 04:58 PM   #9
Thanks for the links and the good words everyone. I've done some more reading on various websites. My TT is about 7000# loaded up and I'm towing with the Ram 1500 Crew Cab 5.7L. It seems that the only difficult part is the wiring and getting the wires on the 7 pin identified correctly. Dont know if there is standard color coding or if you need to trace them. Anyone have any experience with the wiring of the Hydraulic actuator for the brakes?
Old 01-20-2017, 05:13 PM   #10
2007 WildCat 32QBBS
18CrewDually's Avatar
Blue "usually" represents electric brake.
I'd pull the plug apart and see what color is used. Then remove the cover of the junction box that the pigtail is going into and see what color is mated to it.
Here's the diagram of the terminals on the plug.
18CrewDually is offline   Reply With Quote
electric, hydraulic
