Old 04-25-2010, 02:57 PM   #1
Electrical Help
I ran a electrical cord to my Camper to check out the inside lights and when
I plug it up it throws a circuit breaker in my garage on the receptacle
Was working fine yesterday. Any thoughts? Does not throw any thing in the camper.
Olratlr is offline   Reply With Quote
Old 04-25-2010, 05:16 PM   #2
NWJeeper's Avatar
Need more info.
What size and length is the extension cord? How many amps is the outlet (15 or 20 amps) that you are plugging into.
Given a long enough extension cord and low amperage on the outlet it is possible that your converter/charger is pulling enough amps to trip it. Try plugging directly into an outlet if you can reach one.
Ed & Wendy
www.nwjeepn.com
Old 04-25-2010, 06:43 PM   #3
Originally Posted by NWJeeper View Post
Need more info.
Thanks NWJeeper the cord is at least 25 ft 12 gauge 3 prong 20 amp:
I will move it closer tomorrow and try the Camper Cord and see what happens.
Old 04-26-2010, 06:22 AM   #4
KyDan's Avatar
Is the outlet in your garage a ground fault outlet???
KyDan is online now   Reply With Quote
Old 04-26-2010, 06:52 AM   #5
Yes it is Dan.
Old 04-26-2010, 09:38 AM   #6
I think that is your problem. I had a similar experience plugging my camper in at a friend's house in his pumphouse to a GFI plug. Moved it to a regular extension cord plugged into his house and it worked fine. Randy
Old 04-26-2010, 10:35 AM   #7
Thank you Guy's for your help. I will try the house current and if that don't work it's off to my friendly RV Dealer.
Old 05-10-2010, 04:09 PM   #8
I just thought I would let you know I changed out the GFI to a house receptacle
and now I have power. Thanks very much.
wildwood
