Old 05-29-2017, 06:57 PM   #1
Electronics down - 2018 Wildwood T27RKSS
I just bought this Travel Trailer about three weeks ago and now the electronics are down. It has a wireless controller and a wired controller and neither of the following are working, Slideout, stabilizer, awing, nor the front jacks.
I have pulled the battery straps to simulate a reset but no luck. I have no idea where the receiver for the wireless controller is
Does anyone have any quick suggestions, today is memorial day and no one is open. Any help will be greatly appreciated.
tr911 is offline   Reply With Quote
Old 05-29-2017, 06:59 PM   #2
Check the fuses. Does anything else work? If not, it may be the remote control.
otrtrucker is offline   Reply With Quote
Old 05-29-2017, 07:10 PM   #3
Yep, thats my next stop (fuses). Everything worked when I was preparing for travel. And yes everything else works the radio, electric tongue jack, led lights, all of those work. it is just the rear stabilizer jack, slideout, and the front jacks. I tried the buttons at the control center also not just the remote. neither one will work.
Old 05-29-2017, 07:27 PM   #4
Did you get a look at the fuses? I beieve those are on a 30 amp blade fuse, together.
pbrown1988 is offline   Reply With Quote
Old 05-29-2017, 07:48 PM   #5
They are on a separate fuse block. On my 27 RLSS it is under the kitchen sink. Look around in that area.
It looks like this:
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 05-29-2017, 08:16 PM   #6
Found it and it was the 30 amp blade fuse. Guess I need to get a box of them if they blow that easy.
Thanks Guys for the help..
Old 05-29-2017, 08:19 PM   #7
Get an assortment of every size that is in your fuze box. Glad you found it.
Old 05-29-2017, 10:24 PM   #8
As he said, grab an assortment. It doesn't mean you have a wiring issue (if it keeps popping that same fuse frequently I'd look into it), any time you plug in and unplug from a power source (including your truck) you can pop a fuse. To explain that, if you unhook your trailer from camp and don't pull it straight and quickly you can kind of surge power (it doesn't take much). Same goes for hooking your power up as well. Electricity moves a lot faster than the human hand. Now, you shouldn't be throwing fuses in it every time you move the trailer or plug in at camp, but every now and again is certainly not uncommon.
Old 05-30-2017, 05:37 AM   #9
Was it a fuse block like pictured above? Where was it located?
Old 05-30-2017, 12:57 PM   #10
jtesta1's Avatar
Go to amazon. I picked up a set of fuses for cheap.
jtesta1 is offline   Reply With Quote
forest river, wildwood
