Old 06-19-2014, 06:12 PM   #1
Fan constantly runs
I am a new owner of a 2000 forest river Trailor. The furnace fan constantly runs. I have thermostat set to auto. Any ideas what could be wrong?
New propane and new valves. Hear works great and when gets to temp fan continues to blow
rmurphy1120 is offline   Reply With Quote
Old 06-19-2014, 06:14 PM   #2
Not sure of the problem, but the fan WILL run for about 10 minutes after you do reach temp set, to get all the heat out of it.
Mark B.
2021 GMC 1500
Anderson WDH
markb5900 is offline   Reply With Quote
Old 06-19-2014, 06:16 PM   #3
Its been running all day. I can only shut it off by disconnecting from power or turning battery switch off. Once I reconnect, it turns back on. I have turned to off and still no luck.
Thanks for responding Mark
Old 06-19-2014, 06:18 PM   #4
You have a problem with the control board then.
Google your exact model and replace the control board.
Mark B.
2021 GMC 1500
Anderson WDH
Old 06-19-2014, 06:19 PM   #5
thank you
Old 06-19-2014, 08:23 PM   #6
replaced board and still runs
replaced board and still runs?
Old 06-19-2014, 08:26 PM   #7
BamaBob's Avatar
New unit=Dealer's problem. Take off auto use as necessary and take back to dealer for repair. Problem Solved
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-19-2014, 08:29 PM   #8
not a new unit. Its a 2000.
Old 06-19-2014, 08:52 PM   #9
Put a switch on it.
Old 06-19-2014, 08:54 PM   #10
Seriously. The switch is the control board
Old 06-19-2014, 08:57 PM   #11
I put a switch on mine to make it run all the time with the burner off just to circulate the air/heat from our EdenPure electric heater in the winter.
fan
