Old 10-26-2013, 06:48 PM   #11
Yes IDA. The slide out is rubbing on right side at top. I looked underneath the slide out but i don't see any motor. Trunidator said the motor is behind the outside fascia. I am not sure where to look
guydot is offline   Reply With Quote
Old 10-26-2013, 07:03 PM   #12
trudinator's Avatar
I was referring to the trim above the wheel wells. I would think your motor is behind this area somewhere.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 10-27-2013, 09:31 AM   #13
Carknocker Family
Ida Ratherbe Camping's Avatar
Was just trying to get you to look at other options before you tore your campers insides up for no reason. Still think that the motor is underneath. If the slide is moving, dont think the the motor is your problem anyway. You have a have a weld broke on the track or a roller that has givin up or shifted to cause the sag you are describing. There may be an adjustment process that you can do but with out knowing what kind of slide you have, it would just be a shot in the dark. Any idea as to what kind it is?
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 10-27-2013, 09:39 AM   #14
Ford Idaho's Avatar
"outside fascia"
Old 10-27-2013, 02:20 PM   #15
Tks Ida,
I agree with you. The motor will be under the slide out, it will make no sense to have it behind the fascias. I been trying to find out what kind of slide out i have but so far no luck. The slide is moving but i was told i need to get to the motor in order to make adjustment to the slide. Tks for your time
