10-29-2014, 03:28 PM
First time modifications
Being new to a TT my question is, what are the FIRST few mods that I should be thinking about doing? Also coming from tents paper and plastic utensils are the norm what about with the TT? Very excited I have the credit card in hand and ready to go
Oh also are any of the clubs like Good Sam worth joining?
10-29-2014, 03:32 PM
Before you plug in get a Progressive Industries EMS, best piece of mind we did!
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
10-29-2014, 03:43 PM
Another rat in the race
LED light bulbs
two batteries (if you don't have them)
Flag holder (for cheap us flag)
velcro straps for hoses and wires
12V dc jacks around the trailer for charging and small things away from shore power
cheap harbor freight solar panel (mine is 1'x 2' 1 amp ish or something like that)for charging batteries while stored.
one of those battery operated motion sensitive led lights for next to the door and lights for the compartments
get the burger paper sheets and burger baskets so much better than paper plates.
also if you have kids or parties buy fitted waterproof sheets and fitted sheets for the beds then use cheap sleeping bags (it is camping). this way if there is a spill (or other) just strip the fitted sheet and sleeping bag take to the laundromat and away you go. I don't do that for my queen but I do it for all the other beds in our trailer.
those are the ones that were easy and cheap. And you wouldn't believe how nice they are.
I am sure other people have other ideas.
A rainy day camping is better than any sunny day at work
2004 F250 V10 SD Xcab 2011 Wildwood T26BHXL
10-29-2014, 04:25 PM
Good Sams is part of CW same CEO , good to join for discounts and towing, The first thing to do is make it safe, get some TST tire monitoring system for your tires it will let you know tire pressure and temp. The second thing is if you have a WFCO converter throw it away and get a progressive 4600 direct replacement but has a 4 stage charger not 3 like a wfco, they are cheap junk. Also check your tires date and brand and get new GY Marathons or Maxxis. Be safe. That just cost you about $1200.00 but you will thank me oneday... and.. most of all.
Coachmen M/H
Concord
2018 / 300 DSC
10-29-2014, 05:22 PM
Hi there VT Skier! So glad you found this forum!
Here's a couple of add-on to what's been said so far:
1) water regulator - we chose the 'Watts' brand
2) external water filter
3) water bandit or water thief
There are soooo many other nicety things I could add, but these are three easy things to get that I feel are more important
Michelle Evans
Katy, TX
2011 Carriage Cabo 341
2014 Wildwood 231RBXL - Traded Her In
2016 Days Camped = 5; Reserved = 14 so far
2015 Days Camped = 24 / 2014 Days Camped = 23
10-29-2014, 05:40 PM
Would not waste the time or money on changing the converter when it is working just fine and you get absolutely no benefit from it. Had the WFCO converters the last 8 years in 4 different trailers and absolutely no problems with batteries, etc.
10-29-2014, 05:47 PM
This was my first mod. Had it installed before our first trip.
2011 Traverse LT, 3.6L, FWD
10-29-2014, 05:54 PM
This was my 2nd mod: (Use a piece of plexiglass and stainless steel nuts/bolts)
10-29-2014, 05:58 PM
#3 was plexiglass on the bathroom cabinet.
#4 was a splash guard.
10-29-2014, 06:07 PM
I forgot this best thing I ever installed on a trailer. Each big mark is one 2x10 or an orange brick. so much easier when leveling side to side most times I can level it by just parking forward or backward a foot or two
10-29-2014, 07:36 PM
Sorry but what is this or what does it do?
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
10-29-2014, 07:52 PM
Does it work like a mirror to help hitching the trailer? Just a guess...
10-30-2014, 08:03 AM
I suspect that it's a type of sight glass so the one can see from which bottle the regulator is drawing.
Actually think it's a great idea as I find myself taking the bottle cover off to accomplish the same thing. Especially when I know one bottle is getting low and I'm expecting the regulator to flip to the full bottle.
2008 Honda Ridgeline
2013 Rockwood Mini Lite
10k Equali-i-zer WDH
Tekonsha Prodigy P2 Brake Control
10-30-2014, 11:09 AM
"O" contrar OC a progressive is a very good 4 stage charger that will allow you to choose your charge rate. Great converter charger for people who do not stay tethered to a power pole while camping all the time. A progressive with the wizard allows you to control your charge, perfect for someone who likes to boondock and has to charge there batteries by a generator, they can put it in bulk charge anytime they want 14.4 volts to get the max charge rate of 90% of any size they pick such as 45 amp to 100 amps. You can not do that with a WFCO. Also a WFCO will not do desalinization of your plates every 21 hrs,. I don't think FR would be putting them in if they didn't see the benefits over WFCO.
Coachmen M/H
Concord
2018 / 300 DSC
10-30-2014, 12:20 PM
Had camping trailers since 1976 and never had a problem with whatever converter was installed and no battery problems. I stand by my statement, don't waste the time and money replacing a perfectly good converter, now, if it goes bad, replace it with whatever you choose.
BTW, it's "au contraire".
10-30-2014, 12:47 PM
BIG DEAL : Only thing your correct about.. ... ... .... ...Didn't know your a spelling teacher always failed that, but you sure got the point didn't you.....
Coachmen M/H
Concord
2018 / 300 DSC
10-30-2014, 01:11 PM
Why would you spend money replacing a perfectly good, functioning converter?
10-30-2014, 01:28 PM
Not nessecarily mods but stuff to do.
Get some treated 1X10 and 2X10 cut to varying lengths to use to level your trailer or buy plastic block leveling kits (wood is cheaper).
Buy or make some wheel chocks.
I would look into a whole trailer surge/power protection. Search around the site and you will find a bunch of posts on this.
Mods I have on my list for this winter are 5X5 fence post storage for my sewer hose, black and grey tank turbo flush (or similar) and extending the various water drains under the trailer to frame mounted valves.
10-30-2014, 01:40 PM
Read post 14 again, I explained it to you already. Please do not try an bate me into a silly argument. You have your opinion and I have mine. What I said in #14 makes perfect sense to me and is my opinion that's all, disagree if you want but don't say it's wrong facts are fact period..... ..
Coachmen M/H
Concord
2018 / 300 DSC
10-30-2014, 03:09 PM
[emoji85] [emoji86] [emoji87]
Turbs
