Old 04-20-2015, 10:18 AM   #61
Crockett's Avatar
Originally Posted by Herk7769 View Post
I spotted a leaker early on at the turboflush fitting. It only leaked water into the camper when I was outside running it, and it was under and behind the cabinets.
Just happened to notice some water near the water pump (same cabinet) and figured it out while trying to find the non-existent pump leak.
I did not "winterize" the turboflush and the fitting cracked.
I wonder if something like that could be mounted below the floor line?
Crockett is offline   Reply With Quote
Old 04-20-2015, 10:20 AM   #62
Originally Posted by Crockett View Post
hello...my name is david. insurance companies DO pay claims like this. I have proof. I have repaired numerous floors like this under insurance and have documentation. I have also written all the major carriers about the industry standards that lead to this condition. floating vinyl is what allows huge swathes of floor to degrade in very little time. though not said, im sure the industry went this direction due to movement at the joints rifting the vinyl. at least thats what I thought till I saw the jayco vid on the "why" thread. some mfg still do the "full spread". at least one industry rep here says your negligent. an owner, using due diligence should see water and correct. my contention is, if the water is under the vinyl, who can see it? thats why I mentioned the molding at the floor line. I saw no staining on the molding. the sofa base and cabinets, are they just stained or rotted? these are the components on which you build your case.
Interesting. I still have the vinyl sheet with all the mold under it. I also kept the large piece of board with the wet insulation on it. Everything else camp out like wood chips.
The sofa base and everything above the vinyl is fine. The reason it is toast is it fell apart when removing it- it was poorly constructed.
2010 Wildwood X-Lite 18BHXL Backpack Edition
bsdmom is offline   Reply With Quote
Old 04-20-2015, 11:05 AM   #63
Crockett's Avatar
as I said before. do no more work. let the adjuster come have a look. get good pics of all above the floor line and below. the molding shows no water above. check local shops there to see if any have done this repair. small guys who might not even have a RV sales facility. I try to schedule for the winter to keep staff on. it would be good to have a local advocate. ill dig for a state farm claim. the floors Ive done the people are keeping. havent had one sale im aware of. you shown due diligence. what is full coverage for? this is a catastophic event...
Old 04-20-2015, 11:14 AM   #64
Boss Ox & Drovergirl
oxcamper's Avatar
Just curious, did you have a cover on it over the winter?
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 04-20-2015, 01:51 PM   #65
tlambert's Avatar
Floor (and likely walls) completed rotted... devastated
post #17 and #45
Tim
Tim
tlambert is offline   Reply With Quote
Old 04-20-2015, 04:01 PM   #66
Yes, cover on all winter. Looks like adjuster will be here Wednesday. It has been raining since last night. Afraid to go check the camper.
Old 04-20-2015, 04:12 PM   #67
vinmaker's Avatar
Stay strong mom. We all feel for you.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 04-20-2015, 04:52 PM   #68
Crockett's Avatar
set loose items out of weather. get those photos?
edit: no need to post. have for adjuster showing no water on the cabinet bases. ill look for the estimates I have
Old 04-20-2015, 05:04 PM   #69
Crusader's Avatar
I would be vary surprised if your insurance company will cover water damage, from a roof or window leak. Most companies will tell you that it falls under maintenance, and it is not covered. I had two friends that had the same problem you have, and that’s what they were told. I wish you luck with your claim !!
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 04-20-2015, 05:57 PM   #70
Timex's Avatar
Mom you mentioned that you stored the trailer at the place that did the maintenance, was there any written agreement that they would be accountable for any damages occurring while they had it on their property?
Just throwing this out there...
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
