Old 06-30-2014, 11:53 PM   #31
Maybe I am just overlooking something, but the Owners Manual for my 2008 26TBSS makes no reference to how to jack the trailer to change tires. No mention of jack placement or anything. I actually need to replace the tires on mine and was going to take them up to the local tire shop two by two to get them mounted on the rims and balanced.
While searching this and other forums for tips, I found many different opinions on where to jack it (and where not to), so I did what I thought was right and checked the owners manual to find nothing but a section on tire care. My goal is to take two tires off, have them replaced at the local tire shop, bring them back and then do the same for the other two.
The tire shops near me (Kaufmann and Discount) both have very small lots with limited space for maneuvering, so I thought this would be the best approach. Any advise from the owners of these TT's about how best to accomplish this? Any and all advise is welcomed!
2008 Wildwood LE 26TBSS
2011 Ford F250 XLT Crew Cab 6.2L
coldbrew is offline   Reply With Quote
Old 07-03-2014, 10:14 PM   #32
Bryce's Avatar
At home, I just use a 3 ton floor jack under the axle I need to get a wheel off of. On the side of the road, the jack for my F-250 does the trick. I've never had more than one wheel off at a time.
'01 F-250 PSD CC 4x4 SB
'08 Wildwood LE 26TBSS
State's we've RVed in
Bryce is offline   Reply With Quote
Old 07-03-2014, 10:43 PM   #33
Batts-toy's Avatar
Lay down boards/blocks and with your TV hooked up pull one tire on each side up onto them and take the other 2 tires off then reverse the process for the other two.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 07-03-2014, 11:29 PM   #34
Thanks guys! A friend of mine is letting me use one of his spare 15"wheels, so I am going to use a bottle jack under the end of one axle (between the u bolts), take the tire off and put on the borrowed tire and then jack the other axle end up and take both tires to the local tire shop to have new tires mounted and balanced. Then I'll do the same for the other side.
I was hoping to put on Marathons, but Goodyear only makes the Marathons up to a C load range for the 205 75R15. Carlisle makes a radial with a load range of D that would give me the extra "buffer" over the GVWR, but I am unsure about the Carlisle tires. I will be doing some review reading! Afterall, they might be great tires as long as they are properly inflated, speed kept to 65 and the weight not maxed out.
Old 07-04-2014, 02:10 AM   #35
Batts-toy's Avatar
I suggest you go with Maxxis tires. went with 'E' so had to get rims also.
Name:	New Maxxum Tires and rims.jpg
Old 07-15-2014, 07:14 PM   #36
almightywad's Avatar
Did everyone else's 26TBSS come with five bias ply tires??? I don't want to immediately go out and buy five radial tires but I don't like bias ply for this rig. What are all of you doing with your bias ply tires if you have them?
2014 Wildwood 26TBSS
2014 F-250 Lariat with 6.7L Powerstroke Diesel
almightywad is offline   Reply With Quote
Old 07-15-2014, 10:39 PM   #37
Bilcin's Avatar
My 4 tires on my 2011 26TBSS(my unit did not come with a spare &#128550 came with nitrogen filled bias ply tires.
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 07-16-2014, 01:07 AM   #38
Batts-toy's Avatar
My 2013 26TBSS came with 'C' rated radials which are rated to barely cover the weight of the TT and at 50# of air felt mushy when towing, I took it camping one time then went and had them (and the rims) replaced with 'E' rated (80#) Maxxis (scroll up to previous post for photo).
Old 07-16-2014, 08:35 AM   #39
Whoa! Didn't even think I might not get radials on my camper. I'm going to have to double check. I will say that last summer we had a problem with an axel (or hub) being misaligned at the factory. We rode one tire bald on the way to Rushmore, and another on the way home. FR paid to replace all 5 tires. So now I have no idea what it came with. But I'm going to find out what the repair shop "sold me".
Ottawa, KS
2013 Forest River Wildwood 26TBSS
2010 Nissan Armada SE 4x4
Http://campingkansans.blogspot.com
Jhawkfan44 is offline   Reply With Quote
Old 07-16-2014, 03:59 PM   #40
I guarantee you they will be bias ply.
26tbss
