Old 03-17-2019, 08:23 PM   #1
Fresh water inlet will not let water in
Hi,
I have searched the forum for this issue with no luck. I have found similar problems but not exactly like mine.
First of all ... I'm a newbie. This is my first trailer. I just recently bought a new-to-me 2015 Wildwood X-Lite 241QBXL.
During the walk through the tech told me he partially filled the fresh tank to test the water system.
This weekend I brought some water jugs to my trailer to try to gravity fill the fresh water tank via the fresh water inlet. I attached my hose, climbed a ladder to get some height, put a funnel on the other end of the hose and started pouring water in.
The water filled up the hose and then it filled up the funnel. I moved the hose around thinking that maybe it was a gravity problem but nothing I did would help the water actually go into the inlet. It's as if the inlet is blocked.
What is going on? I know that the fresh water tank is underneath the bed which is no where near the fresh water inlet so I'm wondering if maybe gravity feed just won't work?
chetcampbell is offline   Reply With Quote
Old 03-17-2019, 08:47 PM   #2
cavie's Avatar
I have to ask. Is it possible the tank is full?
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-17-2019, 08:50 PM   #3
Mr. Dan's Avatar
Can you post a pic of your "fresh water inlet"?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 29; booked = 12
Old 03-17-2019, 08:51 PM   #4
It is not. The panel reports it is empty. Plus, I removed the board above the tank to see if perhaps there was a port that I could poke a hose through to fill it directly (there's not). It was definitely empty when I looked at it.
Old 03-17-2019, 08:58 PM   #5
Sorry, I do not have a picture of the ports. On this model the city water port and the fresh water intake port are next too each other on the driver's side toward the back of the unit (the fresh water tank is under the bed near the front). Each port has a cover and is threaded to accept a standard size water hose. Each has a little rounded screen to prevent insects from getting in (at least that's what I think the screen is for).
I found a pic on the internet. Both ports look exactly like this: https://pantherrvproducts.com/jr-pro...olonial-white/
Old 03-17-2019, 09:07 PM   #6
Mr. Dan's Avatar
OK, if the fresh water inlet is threaded for water hose, it's not a gravity feed inlet as is mine. I think yours MAY need to be pressurized to be filled.
Old 03-17-2019, 09:17 PM   #7
That sure how it seems. The guy at the dealership partially filled it. So it must take water and my guess would be that he used a hose attached to a faucet. I guess then that I'm going to need to get a small water pump to pump water from my jug to my trailer. I can only hope that the pump generates enough pressure!
Old 03-17-2019, 09:22 PM   #8
rsdata's Avatar
I have used one of these Harbor Freight pumps connected to a garden hose... works good if you have 12 Volts close by
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 03-17-2019, 09:30 PM   #9
Hi,
I know this might be a silly question, but why are you trying to fill the city water tank this way?
If you need water, why not just fill the FRESH water tank ?
Teresa CAL is offline   Reply With Quote
Old 03-17-2019, 09:37 PM   #10
I am trying to fill the fresh water tank. And the problem is that it won't take water when I try to gravity fill it.
My unit only has three tanks: fresh water, gray waste water, black waste water. It does have a city water intake, but my understanding is that it provides water to the sinks, shower and toilet using the city water pressure but it does not fill the fresh water tank.
fresh water, water
