Old 09-24-2019, 06:56 AM   #1
Fresh Water Tank Filling Up on Shore Water??
About to leave for a couple days of enjoyment and had my outside water hose hooked up to the camper. After taking it off, I turned on a faucet and water was coming out. Opened up my low drain and turned on the water pump and water is still coming out. Fresh water tank is full?? I did not put any water in it. Suggestions?
Mike
Mike Gray
Forest River Wildwood
2018 230BHXL
2015 Sierra SLE 5.3 V8 4x4
Mike223 is offline   Reply With Quote
Old 09-24-2019, 07:02 AM   #2
Check valve on your water pump is probably stuck open, and it allows the FW tank to fill while your on "City Water" There is a procedure to try to get the valve unstuck that is usually successful. There is a link on here, but I haven't found it yet.
TheWolfPaq82 is offline   Reply With Quote
Old 09-24-2019, 07:09 AM   #3
My major concern is will the fresh water tank overflow or burst from not having anywhere to drain?? Don't want the TT to fill up with water??
Mike
Mike Gray
2018 230BHXL
Old 09-24-2019, 07:14 AM   #4
Should be an "Over flow" line coming from the tank and usually has a hose attached and runs out the bottom of trailer. That's how most are anyway.
Old 09-24-2019, 07:16 AM   #5
Flybob's Avatar
This issue is posted several times a month. This usually resolves the problem.
Disconnect city water.
Turn off water pump
Turn on any faucet and allow water to run until stops.
close faucet.
Turn on water pump
open any faucet and allow water to run for 30 seconds
close faucet and wait for pump to stop.
Turn off water pump
reconnect city water.
This will reseat the back flow valve in the pump. Do not run water pump with city water connected.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-24-2019, 11:40 AM   #6
Fulltime family RVer
There are a few options for fixing it if resetting the pump doesn’t do it:
https://learntorv.com/water-pump-check-valve/
ependydad is online now   Reply With Quote
fresh water, tank, water, water tank
