Old 05-05-2018, 09:31 PM   #1
Fridge
2016 Heritage Glenn272rl. Fridge not working and the receptical in the wall beside the fridge also does not work. the 15amp fuse is good. The breaker is not tripped. We were cooking and had griddle and electric skillet pluged into the one outlet. They both quit working as well as the fridge.
Buckeye76 is offline   Reply With Quote
Old 05-05-2018, 10:15 PM   #2
If you had a griddle AND a skillet operating on one outlet and/or circuit at the same time, I'm pretty sure you've tripped a circuit breaker, as that's quite a load, especially if the fridge was running on electric and on the same circuit.
Other possibility is you tripped the GFCI that protects the outlets. Look for a GFCI outlet in your bathroom. All the other outlets are probably daisy-chained off of it.
2011 Traverse LT, 3.6L, FWD
Old 05-05-2018, 10:24 PM   #3
x's 2 Check the GFI outlet in the bathroom. Reset if tripped. When you check breakers don't just look. Turn them off then back on.
Old 05-06-2018, 05:40 AM   #4
I have taken fuse out, and looked at, it’s good. I also reset the breaker. Turning off and back on. Also the gfci in bathroom also been reset. Still nothing
Old 05-06-2018, 07:51 AM   #5
small probability that this will help. there have been many posts about circuit breakers being mislabeled. try resetting all circuit breakers including the main. (flip all the way off and then back on). also, do you have any 110 volt power? you could reset the pedestal (home) circuit breaker also. it would be nice to know if you have 110 volt power into the trailer but just this one circuit not working. does the a/c run?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 05-06-2018, 08:39 AM   #6
fuse is for 12 volts. you have a 120 volt problem.
Old 05-06-2018, 08:40 AM   #7
Reset all the breakers. Not just the labeled one. They are marked wrong very often.
Is the GFI you reset working?
Old 05-08-2018, 01:34 PM   #8
Bayoudave's Avatar
GFI bad
GFI are notorious for going bad once tripped. I would expect that is your issue.
Have had that problem twice. If you are comfortable pulling the receptacle out and take your multimeter and check to see that you get power through the GFI.
It will appear to reset but doesn't. Or you could just replace it. I'll bet that fixes it.
2017 Forest River Wildwood X-Lite 254RLXL
2006 Ford F150 XLT
2002 Honda Goldwing 1800 MotorTrike
Bayoudave is offline   Reply With Quote
Old 05-08-2018, 04:03 PM   #9
You also may have more than one gfci receptacle. It could even be outside the unit.
Gotta go campin!
Old 05-08-2018, 04:21 PM   #10
+2
fridge
