Old 07-27-2013, 11:28 PM   #11
Tincup13's Avatar
No problem anything helps
Tincup13 is offline   Reply With Quote
Old 07-28-2013, 12:39 AM   #12
Rebel702's Avatar
Originally Posted by arff2108 View Post
Yes the Galley is the kitchen, just wish I could find the capacity of the tank. not listed in any of the paperwork.
FR website lists grey water as 69 gals. That would be two tanks at 34, one for the bathroom and one for the kitchen.
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 07-28-2013, 06:50 AM   #13
Herk7769's Avatar
"Defective" is a relative term when dealing with the tank indication system.
The kitchen sink gets tons of grease and food particles and since the level indicators use resistance to determine liquid level, any electrical path from the probe to the ground probe will show as some level of "fullness."
The more "shorted" the probe is, the "fuller" the tank will indicate.
Even the 1/3 probe will indicate "full" is the resistance to the ground probe is low.
ID:	36343   Click image for larger version
Name:	Horst Probe Install 008.jpg
ID:	36344   Click image for larger version
Name:	Horst Probe Install 009.jpg
ID:	36345   Click image for larger version
Name:	Horst Probe Install 039.jpg
HAM CALLSIGN - KC3FFW
Old 07-28-2013, 06:53 AM   #14
Herk7769's Avatar
This video from Horst Miracle Probes (which I recommend - with one exception - see my review) explains how the system works.
Horst Miracle Probes Demonstration by Jim Grich of AmericanRVer - YouTube
Old 08-02-2013, 11:36 AM   #15
I have a similar problem with the galley tank. Says 2/3 full, so tried to dump on my 7 day schedule. Valve will not open. I suspect the valve is stuck shut or the cable is broken. Ran water with valve open and nothing came out. So I get to do battle with FR on some more warranty service.
David
2014 Sandpiper 35ROK
2004 Volvo VNL64T 630 left tandem
D-12 435 HP 740 CU
Western Golf and Country Cart (custom body, EZ-GO frame)
Arguing with some people is like trying to smell the color 9
Volvodriver is offline   Reply With Quote
Old 08-03-2013, 03:01 PM   #16
Stg1's Avatar
Galley water, I have 2014 Wildwood 27RKSS. 1 black tank 32 gal. and 2 grey tanks both total 69 gal. I checked under the TT the galley tank is smaller than the main grey tank and is plumbed to the central grey valve, the main grey tank is also plumbed into the same line. The galley tank has a separate valve which is located just under the slide opening at the back (rear kitchen) That way you can empty the main grey tank then the galley. Don't know the exact capacity for the galley tank , but looks like about 20 gals.
Steve and Marlene and 2 Furry Kids. LB (Maltese) Rocky (Border Terrier)
2013 Coachmen Catalina 25RKS 2006 Nissan Titan Crew Cab
Stg1 is offline   Reply With Quote
