08-20-2017, 01:14 PM
#21
Originally Posted by jeffnick
"I wanna run everything at once," is an expensive requirement.
I can run the 13,500 a/c and the microwave and converter with this - and I can light it up or turn it off while lying in the sack.
One More Time Around: Wolf Pup - Generator
Tell me more about this. It's got a remote start? How big is it?
08-20-2017, 01:32 PM
#22
amazon, everything but the remote, apparently what I've gotten so far from the company as they don't make a remote for this size generator only the smaller ones
08-20-2017, 01:49 PM
#23
Location: Alberta - East of the Rockies, West of the Rest
Originally Posted by 5picker
A quick reference is how many amps is your camper? Amps X Volts = Watts.
A 30 amp service needs 3600 watts.
A 50 amp service needs 6000 watts.
Wrong, that's 12,000 Watt divided between two hot legs plus neutral and ground.
Edit: 120 Volt and 50 Amp per leg.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
08-20-2017, 01:56 PM
#24
Here is what I would do, buy a 2000 Watt Honda or Yamaha inverter that can be run in pairs (several others fit the bill also - google is your friend) and buy the 2nd unit if or when needed. Saves you from breaking your back and is much more fuel efficient.
Ordered: 2021....
08-20-2017, 04:15 PM
#26
Summer2Go
Will Harbor Freight honor their 20% coupon on a generator?
08-20-2017, 06:04 PM
#27
According to the small print, 20% off 1 Item only, cannot be part of the any other sale or item listed .... and the Predator is one of listed item!!!
So no you can not use the 20% off coupon!
08-23-2017, 07:37 PM
#28
I have the champion 3400 ,, runs off gas or propane. Not too loud and runs my 13,500 btu ac plus lights, tv, water pump, DVD player with no problems. Love it and half the cost of hondas and yamahas.
09-08-2017, 11:33 AM
#29
Thinking about going with this system:
2 of these generators at $399 per.
1 splitter at $49.
$850 pre-tax. Thoughts?
I own a Wildwood 261BHXL.
Thanks for everyone's help...
09-08-2017, 11:34 AM
#30
I know the price says $499, but they're $399 this month
