Old 11-26-2014, 03:33 PM   #11
Cannonman
Is that Alta or Snowbird?
VT Skier is offline   Reply With Quote
Old 11-26-2014, 03:35 PM   #12
Originally Posted by acadianbob View Post
2000 to 2400 watts will run about everything except your air conditioner. It will run your microwave, a hair dryer, charge your batteries etc.
Do yourself and everyone around you a favor by getting a nice quiet generator; like a Honda or Yamaha.
Happy Camping!
X2 And an amen on the Honda/Yamaha. Quiet is good.
rana is offline   Reply With Quote
Old 11-26-2014, 03:37 PM   #13
Herk7769's Avatar
Spend the money and buy a Honda 2000 COMPANION. That will do everything but run the AC. http://www.northerntool.com/shop/too...5499_200585499
You can add a second Honda 2000 (NOT the companion) and a parallel kit if the AC becomes an issue. http://www.northerntool.com/shop/too...5434_200585434
http://www.northerntool.com/shop/too...0099_200330099
They make a dual generator feeding fuel kit that will service both generators from the same tank of gas; BUT it ONLY works on the Honda 2000s because they have a fuel pump.
http://www.northerntool.com/shop/too...8951_200408951
OTHER generators use gravity feeds and will NOT work with an external fuel tank.
HAM CALLSIGN - KC3FFW
Old 11-26-2014, 03:40 PM   #14
Originally Posted by VT Skier View Post
Usage would be to recharge battery possible small period where we could use the outlets no AC no microwave.
Then a 1200watt would be fine. Just be aware that a 1200 may not actually be a sustained 1200watts. Read the literature for sustained and surge wattage's. Also be aware that it would not be sufficient to run a heat pump, furnace, or electric heater.
Old 11-26-2014, 03:52 PM   #15
Early and late season we would camp using shore power here in VT not much use for AC mostly just want to keep batteries charged if we are out for 3+ days replacing all the lights with LED'S.
Old 11-26-2014, 04:03 PM   #16
Herk7769's Avatar
That is exactly why buying the correct setup is important. Buy the wrong one first and it will sit in the garage when you have to retrace your steps and buy what you should have bought in the first place.
I almost made a second mistake when I almost pulled the trigger on the 2000 watt champion setup. While it can be paralleled, it does not have a fuel pump and can not be fed from a single larger tank (a deal breaker for me).
https://www.google.com/shopping/prod...&ved=0CJcBELok
Old 11-26-2014, 04:16 PM   #17
Canonman's Avatar
Cannonman
The Bird, Mineral Basin.
We used a 700w generator and found it most adequate for simple battery recharge. We use rechargeable LED lanterns for both inside and outside and and recharged those at the same time (via the outlets in the camper) as we did the house batteries. While we could easily last a couple of days at a time, we found a daily charge would only take about 2 hrs to top off all the batteries.
Camping at anywhere from 6k to 10k ft elevations we often needed the furnace during the night. We had no problems keeping the charge level up with just a couple of hours a day recharge. Changed over to the larger unit when we started camping more in the desert and needed the A/C. Now that's "Glamping"
ID:	66866   Click image for larger version
FR Wildwood 22 RKS
2007 1/2 Dodge 2500, Cummins 6.7
Retirement training completed
Currently enjoying second childhood
Canonman is offline   Reply With Quote
Old 11-26-2014, 07:54 PM   #18
camaraderie's Avatar
VT... You should size your generator at a minimum to power the charger you want to use to charge your battery bank. For wet cell batteries...the charger should be no larger than 25% of the amp hours in the bank...i.e. 50amps for a 200 amp hour battery charger (Batteries will not ACCEPT more than a 25% charging current so buying more charger is a waste.) It will take you at least 4 hours of charging to bring your bank from 50% to 100% charge due to charge resistance. You can get away with less for a few days provided you plug in somewhere to top up to 100%.
Now...sticking with the example I gave...a 50 amp charger @ 14V (approx bulk charging voltage) will require 700 watts + some loss to efficiency so I would size somewhere in the 900 to 1000 watt generator FULL time rating JUST for the charger.
(Note this is about right for a pair of 6V's or a pair of bigger 12V's) If you only have one coach battery...then the genny only needs to be about half that rating
Anything else you want to run at the same time you are charging should be factored in to the size of the genny using the amp draws of the item per Herks list and remembering some loads are AC amps and others are DC... multiply by 120 or 12 respectively to find how much wattage you need extra and DOuBLE it for anything with a MOTOR inside for peak start up draw.
Hope this helps. What ski areas are you near in VT? Lived in Winooskie for a while!
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is online now   Reply With Quote
generator
