Old 06-04-2012, 03:01 PM   #11
I see your thread got moved. Sorry you couldn't get the help or info you were hoping to get. Hopefully posting in your Wildwood forum doesn't ruffle feathers over here...
I'm not sure what waterpumps get put on the Wildwoods, but I believe I read somewhere that the Girard needs like 45psi minimum to operate. If you did do that you would most likely want to set the switch from Auto to Low as the low puts out a lower btu flame to compensate for the slower flow. If I keep my tankless I will most likely install a higher flow higher pressure water pump.
Also, do you have a water filter in your system? The more restrictions to water flow will give you higher water temps. I have seen numerous boost pumps that work with city water to boost the pressure and volume. This may help with the scaulding hot water issue...again if I keep ours I may look into those as well.
What combos have you tried with regards to switch position and turns of the faucet in the shower? I found at one campground Low and half turn of the hot faucet gave good water. Another one, High and full open on the faucet gave good results. My wife and I have been burned several times by this thing and each time I threaten to rip it out. We had a difficult time getting good temps when using our fresh water and ended up running out of water at the end of our weekend stay. You shouldn't have to play with these things to try and get the right temp. Military showers are even worse and you end up wasting more water trying to get the temp back set again then if you just let the darn water run.
I understand your frustrations, know that you really are not alone, many of us Wildcat owners are not happy with these...they are just too inconsistant. However, some have been very happy with theirs. Thankfully now it is not a forced option, but so far no offers have been made to replace these with a regular style water heater for those of us unsatisfied.
2012 Wildcat Sterling 29MK
2011 Chevy Silverado 3500HD LTZ 4x4 D/A
4x4man is offline   Reply With Quote
Old 06-04-2012, 03:11 PM   #12
chuck9997's Avatar
thank you so much for posting.. Thank you for the information. I think you are right.. the bottom line with my unit is water flow. I had the camper hooked up at a CG where the pressure was pretty high (some folks had busted water hoses).. it seemed to work as intended.. in the kitchen. at that time I hadn't been advised how to use the tankless WH with my OXYGENICS shower head.. so showers were never comfortable. I am anxious to try it again.. with some suggestions I found on the WILDCAT part of this forum (when I still aloud over ther..LOL).
I do not have any restrictions that I know of.. no filters or anything in line. The "boost pump" sounds interesting. Is this something I could used when connected to CG water.. I will do a search.. are they called "boost pumps"?
Again.. thanks for the response.. and my apologies to you.. for lumping all the WILDCAT owners together..
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 06-04-2012, 03:33 PM   #13
No worries, no need to apologize. I have learned a lot from this forum and I have been camping for 10 years and this is our third rig. The Wildcat guys are a great bunch, and the reps have been very helpful to me with my service problems. Seemed odd that your thread got moved as I don't think any other forum would have netted you the best audience.
I don't know if I am allowed to post links, but here is info on one boost pump:
Aquatec 550 Whole RV Boost Pump VSD
120 VAC, built-in GFCI protection, 50 psi running pressure, use on in-coming water line to boost RV park water pressure
Old 06-04-2012, 03:40 PM   #14
chuck9997's Avatar
thanks.. I found the pump.. and read up a little. Its a little pricey ($250).. I would weigh that against the cost of having a 10 gallon gas/elec heater installed. For now.. I will try a few options. I really want the GIRARD to work.. but I also like taking comfortable showers.
Old 06-04-2012, 03:48 PM   #15
I to, want the Girard to work out. I don't want to sound like a problem child who keeps harping on the same problem, I really would much like to rave about the positives. When my wife got sick she was able to take a 30 minute shower and didn't run out of hot water. No way she could've done that with a regular 10 gal water heater. I'm torn. Like you, I just want to be able to take comfortable showers, but on the days it doesn't work it really frustrates you.
Old 06-24-2012, 05:43 PM   #16
I have the same issues with the tankless heater. I have. Berkshire 390rb and have not been happy with the heater. I have read and played and I do not get constraint results. I am camping now and will try removing the water filter. I use a pressure regulator some times but seem to have low pressure where we are now. I have used the auto setting and the low setting this is just not consistent temp and I am worried That one of the grand kids will get hurt on this thing. I'm 55 and not stupid so why can't I figure this out.
Old 07-08-2012, 01:36 PM   #17
Angry Tankless water heater.
I just bought my second wildcat fifth wheel. I now have a tankless water heater and regret it. We travel Florida in the summer and with the warmer supply water temperature it is impossible to regulate the water temperature. Water is too hot to the point of scalding, or too cold. Forget dry camping, two showers and water is gone. On board pump cannot move enough water to regulate a safe temperature. I am going pressure the dealer to replace with a tank style. He agrees that there is a serious issue but Forest River is turning a deaf ear. He has had no positive feedback regarding tankless and thinks Forest River made a big mistake installing them.
Until Forest River fixes this issue I will not recommend and wil discourage anyone from purchasing one.
Jimacman is offline   Reply With Quote
