Old 05-04-2018, 05:26 PM   #1
Grill on swing arm of camper low flame
Does or has anyone else had a problem with their outside grill on a 2016 wildwood 261bhxl. We can get it to light but it is only on low and won’t change to high. I have taken it apart and cleaned out the burner and pipes leading to it as well as the orfice of the valve. The burners inside the camper are working fine just the outside grill is the issue
jschmidt is offline   Reply With Quote
Old 05-04-2018, 06:36 PM   #2
There is a check valve between the regulator and the tank valve. It closes when it detects a high flow rate, usually due to a leak, it closes off the flow. That only allows a low flame. Have your regulator assembly checked out.
otrtrucker is offline   Reply With Quote
Old 05-04-2018, 06:47 PM   #3
I did spray soapy solution on the regulator and all the connections and did not see any bubbles could the regulator go bad without a leak?
Old 05-04-2018, 06:54 PM   #4
Yes. I had one on my grill go bad. A propane retailer can check it out, and fix it, if it's bad.
Old 05-05-2018, 05:02 PM   #5
It happens. My regulator was made in China and was acting strangely (not automatically switching to a new tank, low flame in the stove burners after putting the lines, etc.), so I replaced it with an American-made one. Problems solved.
2015 Palomino SolAire 20RBS
2017 1500 Silverado LTZ Z71 with 6.2L, 8-speed & tow package
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 26 days;
elchilero53 is offline   Reply With Quote
Old 05-05-2018, 08:36 PM   #6
My regulator is up by my propane tanks. Wouldn’t it affect the burners on my stove on the inside as well. If it should it doesn’t. Can I take the regulator off and take it to a retailer or do I ha e to take the whole camper to them
Old 05-05-2018, 11:39 PM   #7
It sounds as if your grill is malfunctioning, but don't expect too much from this thing. My grill works as it "should", but it's pretty pathetic compared to a home grill or charcoal. I can't get a sear on anything without squirting oil into the flame (the Carrabba's wood-fired grill technique).
I use my grill for some things...dogs and such...or for overflow from my charcoal grill...or for times when burn bans prevent the use of charcoal.
If you're serious about grilling, there are many good options, but I highly recommend this stainless steel folding charcoal grill. Super light. Comes with a tote back to keep things clean, and it's amazing.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Again, your grill isn't working correctly, and you'll be happy to get it fixed, but as grills go, these things are barely adequate.
Jim & Renee
2014 Forest River/Rockwood HW 277
Typical season is about 30 nights camping, usually nearby boondocking in the National Forests or at Lake Wellington
jimmoore13 is offline   Reply With Quote
Old 05-06-2018, 07:17 PM   #8
BillyBass's Avatar
I had the same problem in the past and when I lifted the hose it shot up higher.I change the quick connect both ends and that solve the problem
2019 Flagstaff 26 RBWS
2005 GMC Sierra 1500
2019 17 nites
BillyBass is online now   Reply With Quote
Old 05-07-2018, 02:27 AM   #9
I could not agree more, what a piece of junk. I like the arm and all that, but have deep seated hatred for the cheap-o grill. I have been looking at a way to install something better but the attachment appears to be quite proprietary. While I am complaining the whole outdoor kitchen is somewhat crap. I really like the Open Range kitchen setup, but not enough to part with another 15k. This on my to do list for mods.
iceclimber is offline   Reply With Quote
Old 05-13-2018, 11:15 AM   #10
Has anybody found an upgrade that fits on the swing arm
camper
