Old 04-19-2014, 03:22 PM   #1
Adony's Avatar
Ground Wire???
When my 2010 Wildwood TT was new, there was a braided (aircraft type) wire welded to the frame and on the other end was attached to one of the screws on either the black or grey water plastic dump valve... today I noticed due to corrosion it has broken off... Is this some sort of ground / bonding wire and should I replace it? Why would you ground a plastic pipe system?
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 04-26-2014, 09:52 AM   #2
It's there to stop electrolysis and grounding the screw
RV Man is offline   Reply With Quote
