Old 06-04-2011, 11:03 AM   #1
Heater
Has anyone had any trouble starting their heater for the first time?
dozrdog is offline   Reply With Quote
Old 06-04-2011, 01:22 PM   #2
bikendan's Avatar
the water heater or the furnace?
Old 06-04-2011, 01:31 PM   #3
The furnace. This is our first trip out in our new trailer. Heater comes on but can't feel any heat coming from the floor vents.
Old 06-04-2011, 01:38 PM   #4
DF5.4's Avatar
Make sure your propane tanks are full. I've had that happen when one tank is low and i didn't have the other one open. Ours will blow cool air at first. After a few seconds the warm air starts.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 06-04-2011, 01:54 PM   #5
Seems like something is blocking the vents or they were not connected right at the factory.
Old 06-04-2011, 02:23 PM   #6
Hot air is blowing out the back of the trailer and no air at is coming out floor vents.
Old 06-04-2011, 02:42 PM   #7
Does anyone know where the valve switch is for the furnace to work?
Old 06-07-2011, 11:34 AM   #8
rracer5's Avatar
Hot air from the outside vent indicates that the heater is "fired up", that's good. Open the panel to access the heater from the inside and check to see if the duct work is connected. If it's just laying in there, then there's your problem. Turn on the heater, if you feel hot air blowing inside the cabinet then it's got to be the duct work connection.
Good luck.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 06-07-2011, 01:16 PM   #9
It always takes several minutes for the vents to start feeling warm after it fires up.
2018 Flagstaff 832IKBS Travel Trailer.
2015 Silverado High Country.
jackhartjr is offline   Reply With Quote
