If you turn on the propane tank valve too quickly there is a safety valve that will sense the rush of gas and shut off in case of a leak, turn off the valve, wait about 10 minutes then turn the valve slowly. It also helps if you light the range burner to help purge air out of the system. The furnace is designed to try to light 3 times and if it doesn't after the 3 tries it will lock itself out.
Richard & Jill
