Old 08-03-2017, 07:03 PM   #1
Height of Wildwood 25RLSS
Called both Forest River manufacturers (mine made in California) and neither can tell me height of my 5th wheel. Want to order a steel carport and need this information. Anyon know? Thanks, Marilynn
Marilynn is offline   Reply With Quote
Old 11-25-2017, 07:33 PM   #2
Bene Gesserit Rule
Murbella7's Avatar
The only real solution is to measure it yourself. Get a digital measuring device (they are cheap on eBay). Drag a length of timber onto the roof and hang it out at the highest section of the roof (you will probably need to weigh it down with a load of other heavy stuff to stop it falling off). Using the digital tool, measure from the ground to the under side of the overhanging timber.
Or, park under an object (service station roof, trestle, low bridge) of known height or you measured earlier and subtract the difference.
All sounds a bit stupid, but I had to do something similar. Tried dangling measuring tape from the roof but could never get the right place to do it. Vents and a/c's stick up from the centre-line, not near the edge.
Murbella7 is offline   Reply With Quote
wildwood
