Old 04-02-2016, 11:25 PM   #1
HELP - 2000 27ft Wildwood Travel Trailer TOW QUESTION
Hi there
Does anyone know the dry weight of the 27ft wildwood travel trailer? I have no idea what the model number is.
It has two doors. A walk-around bed/bedroom, shower/toilet with a separate sink. And then the kitchen in the front of the trailer. There is a couch and a removable recliner.
I cannot for the life of me figure out the dry weight. Is it noted somewhere in the trailer?
Name:   ImageUploadedByForest River Forums1459657455.112952.jpg
Name:   ImageUploadedByForest River Forums1459657476.207947.jpg
Name:   ImageUploadedByForest River Forums1459657492.865916.jpg
Thank you!
Katlouhod is offline   Reply With Quote
Old 04-03-2016, 12:16 AM   #2
CaptnJohn's Avatar
Somewhere ~~ usually in a kitchen drawer~~ on trailers of that time frame is a white sticker. You can check on the door frame. If on the road side outside wall it is probably unable to be read by now. That sticker will give the info you are searching.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 04-03-2016, 12:17 AM   #3
Mr. Dan's Avatar
We can hardly tell you the dry weights of our trailers that are only 2-4 years old - no shot at guessing for a trailer that is 17 years old... plus dry weight numbers are generally as false as the tank "fullness" indicators.
That said, my trailers around that age had a white sticker inside a kitchen cabinet door that told information as useful as you can get without taking the trailer to a CAT scale.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 20
Old 04-03-2016, 12:57 AM   #4
Ok I found it! Here is my info. And then I'll present my tow question.
GVWR 7,550
UVW 5,230
NCC 2,320
We drive a 2015 Nissan NV Passenger van. 7.6L Engine, 3500 HD. Max tow capacity is 8,700 (80% capacity is 6,960). I understand you want to try to keep your max towing at 80% which is why I stated that number.
So based on this information, is our van strong enough to tow this trailer?
Thank you for your opinion!
Katrina
Old 04-03-2016, 01:18 AM   #5
bikendan's Avatar
You didn't provide the van's payload capacity.
It's on the driver's door yellow sticker.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-03-2016, 01:27 AM   #6
asquared's Avatar
What is the payload on your van? Look at the tire loading sticker inside the drivers door for that Ingo. Next subtract the weight of all occupants, pets and gear that will be in the van when towing ftom the door payload number.
Dry weight us a useless number as you will never tow a dry trailer. On average people tend to add 1000-1500 lbs of stuff to a trailer. Given that guess that would put you around 6200-6700 lbs loaded tt weight. Next the tongue weight of the trailer should be 13-15% of the loaded trailer weight. Given those numbers you are looking at 800-1000 lbs tongue weight (1100 If using trailer gvwr and 15% tongue weight).
The loaded trailer weight plus loaded van weight needs to be under the vans gcwr. The loaded tongue weight needs to factor into your payload.... foes the passengers etc plus tongue weight add up to less than the payload? If yes to the above questions then you will likely be ok, if no then keep shopping.
Here is a towing calculator to help figure out what you can really tow. The 80% rule isn't really accurate.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 04-03-2016, 07:20 AM   #7
5er_tom's Avatar
Is that really a 7.6 L engine? That is a very large engine.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 04-03-2016, 07:41 AM   #8
Ambassador
Ken K.'s Avatar
it's comes with a 5.6 liter engine
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
Old 04-03-2016, 12:48 PM   #9
The shortest answer
Is no.
That is just not enough truck to pull the trailer, the load and the passengers. Safely. The least that could happen is burning up the transmission. The worst is an out of control rig full of kids. Somewhere in the middle is sitting on the side of a busy interstate, 5% grade, steaming from the engine, smelling of burned transmission fluid which is boiling out of the filler neck, the radiator making boiling nosies, and the engine dieseling. With your wife saying, "They TOLD you we needed a bigger vehicle!"
Even empty (which it will never be, with just the driver, (which will never happen) it is far too borderline to risk.
Now you might do it anyway, and get 20 years down the road, and sound like an expert when you say "I never had any trouble, the rig handled it like it wasn't even there, etc"... But I sincerely doubt it.
Don't risk it.
hankpac is offline   Reply With Quote
Old 04-03-2016, 03:59 PM   #10
RetiredRVer
If you have the SL model, it has a 3500 pound payload capacity. (according to Nissan)
That, combined with 8700 pound towing capacity, should be enough to pull your trailer. Don't forget a trailer brake controller, a weight distributing hitch, a transmission oil cooler, (unless already equipped) and a 7 pin connector. I pulled my first trailer, about 6000 lbs loaded, with a Buick Lasabre for two years! (Not the best idea, but I couldn't afford a real tow vehicle at the time.). Good luck, and happy camping!
checkmate99 is offline   Reply With Quote
trailer, travel, travel trailer, wildwood
