Old 07-31-2016, 05:15 PM   #1
Heritage GLen 27BH - WH question
We just bought a HG 27 BH
I know we covered at walk through but that was a lot of info
On the WH since it is both elec and gas, where are both switches?
I assuming the elec switch is the one on the panel and the gas part is the one outside where I take the cover off the WH and the little on/off switch in there
Mike
Also how do you drain the WH? just by draining the RV or is there a separate valve?
3boohers is offline   Reply With Quote
Old 07-31-2016, 05:39 PM   #2
Brother Les's Avatar
Mike
On my Hemishpere, the switch inside is for the propane. The switch outside at the water heater is the electric.
If you use the electric (outside), make sure that you shut it off when not camping, as it will boil the water out and burn the element up if it sits too long with no water in the tank.
To drain the water heater (make sure the the electric and propane to it is off), take out the heating element and open the releaf valve to allow more air to get into the tank.
Brother Les
Old 08-03-2016, 01:50 PM   #3
dodosmike's Avatar
In my HG272BH the LPG switch is inside and Electric switch is outside.
I drain mine by removing the 1&1/18" anode rod/plug and opening a faucet. Watch out for hot water!
dodosmike is offline   Reply With Quote
