Old 10-24-2015, 06:34 PM   #11
Scorn, that is the kit you need. Use teflon on the threads.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 10-25-2015, 12:32 AM   #12
tlambert's Avatar
The hose with that kit is a little short. Go to lowes in the plumbing dept they have clear hose that matches that size.
Get an extra length of hose along with a barb fitting to connect he 2 pieces. Sorry I don't remember the ID of the hose at the moment.
This helps get the jug of antifreeze out from under the cabinet when pumping it in the lines.
Tim
Tim
tlambert is offline   Reply With Quote
Old 02-24-2016, 01:34 PM   #13
jgump's Avatar
Or, you could get a blow out plug and clear your lines with air pressure then pour antifreeze in the drains and some in tanks. This is an alternative to filling all your lines with AF. No water in the lines, no freezing up ! Good luck and Happy Camping!
John
2016 Wildwood 27RKSS
2012 Grand Cherokee Overland (Hemi)
jgump is offline   Reply With Quote
bypass, heater
