Old 03-31-2017, 01:27 PM   #1
Heritage Glen 299re lug nut size
Anyone know the HG 299re lug nut socket size? My trusty 4 sided tire wrench is a no go. Thanks.
MartyNH is offline   Reply With Quote
Old 04-02-2017, 07:34 AM   #2
SilhouettePenny's Avatar
If you've got aluminum wheels I can understand why the traditional 4-way won't work, and you don't want to try because it will destroy the thin aluminum cap on your lugnuts. Most likely your lugs are 1/2 X 20 in size, available at Auto Zone.
Go to Lowes and get a 3/4 inch thin wall deep socket, then stop at Tractor Supply Company for a 24 inch breaker bar. Now you have a decicated camper lug wrench. Check for tightness at your first rest area and happy motoring.
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 04-02-2017, 05:16 PM   #3
As Elvis used to say, "thank you very much"!
Old 04-02-2017, 05:35 PM   #4
wmtire's Avatar
As SilhouettePenny stated, your wheel may not be allowing a lug wrench to fit over the lug nut and have room to turn the lug nut with the way the nut is inset into the wheel. You will need a thin wall socket to accomplish this, if that's the case.
Also, you may want to check out this thread, if you have the lug nuts with the chrome veneers on them. It has a pic of the type wheels you may have too.
Is my lug nut split?
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
