Old 04-23-2014, 08:49 PM   #1
Heritage Glen 312 qbud waste tank valves
I am looking at a new 2015 wildwood heritage glen 312 qbud. I really like this TT. I noticed it only has one valve for the waste tanks (black,grey,galley). Am I missing the other pull valves or is it common on some models to have only one pull valve to drain all the tanks? I looked all over but could only locate the one valve. Any ideas?
Also does anyone have any insight into the overall quality of the heritage glen models.
NewGuy is offline   Reply With Quote
Old 04-23-2014, 09:29 PM   #2
Boss Ox & Drovergirl
oxcamper's Avatar
We have a Hemisphere 282RK and although it's a different model I understand the Hemisphere series are the same as the Heritage Glen series just with a different marque so other dealers can offer it. Hemisphere also has a 312qbud model. We are very satisfied with our Hemisphere quality, fit, and performance. I don't think you will be disappointed by your choice.
I am assuming by your comment that there are no labels or decals marking the different waste valve locations? the only pics I could find show the services are located between the 2 slides, but that doesn't mean the valves are necessarily in the same place as the outlet.
Also is there only one connection outlet? With 1 bath, inside galley, and an outside kitchen, it would seem odd. We have a rear kitchen so we actually have a galley outlet connection and valve toward the rear of the trailer in addition to the black and grey outlet and 2 valves for the bathroom near the center. If the control panel has indicators for grey 1 and grey 2 as well as black, then there are 3 tanks, and each tank has a valve. Now my galley valve and outlet is actually under the slide when the slide is extended and you have to crawl under it to get to the components. The position of the Hemi's valves are such that they are right next to the frame when in the closed position so until you know where they are by feel, I have to get down on my hands and knees and look for them. The Black and Gray valves will be near the outlet connection for the bathroom, but not necessarily right next to it. Our grey valve is actually about 2 feet behind the outlet.
If you still can't figure it out, call a dealer and ask to talk to one of the service reps.
Hope this was helpful, happy camping!
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 04-23-2014, 11:04 PM   #3
leencharlotte's Avatar
Previously had the 2011.5 model of the 312qbud and I had 3 valves. 2 (1 on either side of drain connection left was shower, kith/bath sink. Right was black) and one toward rear under the slide by landing gear (outdoor kitchen sink grey tank)
Not sure if they changed but contact dealer to be sure.
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
leencharlotte is offline   Reply With Quote
Old 11-12-2014, 08:01 PM   #4
Mcindia's Avatar
Hi there you have three valves! One is open
To drain all tanks , other is a gray , one is black
Mcindia is offline   Reply With Quote
Old 11-18-2014, 03:45 PM   #5
My heritage glen has 3 front most is galley, just in front is gray for shower and bathroom sink behind wheels is black with the hose connection
kd4dpb is offline   Reply With Quote
Old 07-07-2016, 02:03 PM   #6
I have the 2016 312 QBUD and I have three as well. two grey and one black.
rcmarth is offline   Reply With Quote
Old 07-09-2016, 12:01 AM   #7
I go RV'ing not Camping
jgourlie's Avatar
The handles should be in the same area as the one you found already. Just look way up high near the frame, that's where mine are located
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 07-09-2016, 01:22 PM   #8
I've got an HG 29 BH, and it has 2 grey and a black. The 2 greys are easy to see, but the black is way up behind the skirting. You have to lay on the ground to see it. I didn't realize it, and made a mess, and overflowed my black tank with the black tank flush.
I can't figure out why they put one up so high, but the do.
Wowens79 is offline   Reply With Quote
tank, valve
