Old 04-03-2014, 03:14 PM   #91
Hi, is there any of you having problems with blowing the fuse (30 amp fuse) for the slides. Is the second time I blew the fuse in a month
Sent from my SAMSUNG-SGH-I337 using Forest River Forums mobile app
mario_bovio is offline   Reply With Quote
Old 04-03-2014, 03:47 PM   #92
Chewie's Avatar
No, haven't here.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 04-03-2014, 03:59 PM   #93
I have not had this problem.
rlandry is offline   Reply With Quote
Old 04-03-2014, 04:04 PM   #94
I have had both sink faucets in both bathrooms start leaking after you turn the faucet off. They have replaced both of them. If you are not home and this happens you will have a big mess under the cabinet. Also, the oven does not stay lit after it gets up to the desired temp. The pilot goes out. They are replacing the inside of the stove. Service guy said they are having to replace a bunch of them inthe last couple of months.
Old 04-03-2014, 04:22 PM   #95
Originally Posted by Chewie View Post
Ok. I'd call the dealer. I don't know whether or not this drains to the rear gray or the galley tank. It telescopes out when the slide is moved out. Any other drain issues? Also check the series 300 toilets and make sure they don't have internal leaks. If so, look at the sticky thread in the plumbing section regarding this. Enjoy the new 5er. You will get a ton of looks and questions when you pull somewhere.
Finally got the outside kitchen sink to drain. When they installed the check valve they crimped the valve and it would not let water out. Service guy found it and ordered the part to fix it.
Old 04-03-2014, 11:24 PM   #96
My skylights fans n my stove hood fan also stopped working, I'm wondering if there is another fuse, I looked at the breaker/fuses box n they all looked good, any suggestions?
Old 04-08-2014, 06:59 AM   #97
Very nice camper. We bought the same one over the winter and just got out last weekend for the first time this season. We had several issues and wondered if you've had any of the same?
1. Furnace comes on, lights and goes out. I can feel heat outside on the vent when it lights. Tries 3 times and shuts off. Sounds like a bad sensor or maybe a thermocouple?
2. Light over the stove blowing bulbs constantly.
3. Both lights in the rear bunks don't work, no power to the lights at all? Wondered if I'm missing another switch somewhere?
4. One burner on stove isn't igniting , spark is dying inside the ceramic insert...
Frustrating to say the least, but hoping our dealer takes care of these issues quickly.
This camper replaces our 35'. Love how it pulls. Thanks for the heads up on the toilet issues. We'll keep an eye in ours.
locomotivejoe is offline   Reply With Quote
Old 04-08-2014, 08:29 AM   #98
heavyduty's Avatar
Not sure if anyone on here was traveling down interstate 70 in pa on Monday the 7 but saw a qbq heading west didn't get to see what kind of truck but it was blue is it anyone on here
Sent from my HTC One using Forest River Forums mobile app
heavyduty is offline   Reply With Quote
Old 04-08-2014, 09:42 AM   #99
Locomotivejoe
I had the same problem with the light above the stove and I put a led light bulb n fixed the problem so far, and the lights on the back room where out too but it was just loose
Old 04-13-2014, 05:13 PM   #100
RV maniac's Avatar
Does anyone know where the fuse or breaker is for the main control panel? Cant operate my slides or awning from control panel, have to use the remote.
RV maniac is offline   Reply With Quote
