Old 04-13-2014, 05:20 PM   #101
Originally Posted by RV maniac View Post
Does anyone know where the fuse or breaker is for the main control panel? Cant operate my slides or awning from control panel, have to use the remote.
Sent from my SAMSUNG-SGH-I337 using Forest River Forums mobile app
Check the battery compartment there's one there but aim not sure if it's for everything or just
Ecclesiastes is offline   Reply With Quote
Old 04-13-2014, 05:37 PM   #102
RV maniac's Avatar
Thats a 15 amp fuse and its good. Have checked everywhere and have no idea! Just dont like the idea of depending on just the remote.
RV maniac is offline   Reply With Quote
Old 04-13-2014, 05:51 PM   #103
Sorry this is a doozy Call the factory tomorrow and let us know what they tell you
Old 04-13-2014, 05:58 PM   #104
Fuse and breaker panel is right below the cooking stove inside near the floor.
locomotivejoe is offline   Reply With Quote
Old 04-13-2014, 06:25 PM   #105
There is a fuse in the front compartment but I'm not sure if it is for the front landing gear, if you open the door stick your head in and look up, there is right in the middle
mario_bovio is offline   Reply With Quote
Old 04-13-2014, 06:31 PM   #106
DiverT's Avatar
check behind the rear panel in the basement storage area, there is a panel down there.
DiverT is offline   Reply With Quote
Old 04-13-2014, 06:59 PM   #107
RV maniac's Avatar
Thanks everybody its storming and hailing here but soon as its done I'll check
Old 04-13-2014, 07:00 PM   #108
RV maniac's Avatar
Its not one of the fuses or breakers inside the main breaker panel in the kitchen
Old 04-13-2014, 07:31 PM   #109
RV maniac's Avatar
Ok so its not the 30 amp fuse in the front compartment thats for the landing gear. There are 3 15 amp fuses behind the panel in the basement storage and they r all good also. They all go into a termination block with a couple of relays and from there go to thw main switches inside.
Old 04-13-2014, 08:24 PM   #110
Chewie's Avatar
I cant think of any more fuses than what has already been mentioned. But i'm assuming its also a bad fuse somewhere. Last year I blew the 30a landing gear fuse and it would no longer work with the button, only on remote. So seems like the symptoms are the similar in only the remote working.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
