Old 09-06-2016, 10:15 PM   #1
HG 356qb - 12v question
Since becoming full timers this week we have figured out that we need/want some more plugs in the master bedroom. Hae anyone added some? I was considering going with 12v usb chargers on each bedside for phones etc. Has anyone done this?
Also was considering adding an outside tv to the kitchen, figured i could t off the cable in the bunkhouse, any thoughts on this?
KIPKERS is offline   Reply With Quote
Old 09-07-2016, 05:02 PM   #2
Tfort's Avatar
Haven't done it yet but thinking of doing the same to mine. Not sure on the bedroom but using the cable from the bunk house would be really easy. I had the cable loose back there to find the studs to mount the tv in the bunk room and you can drill through the wall into the outdoor kitchen and cut in a box.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 09-07-2016, 05:27 PM   #3
I found the cable under the slide, looks like i can spit it there and feed it up the wall to a plate under the cabinet. Should be pretty easy
