Old 08-05-2016, 05:34 AM   #1
Hg 356qb wall separation
Anyone had the wall between the living and bunk room pull away from the side wall?
The off door side now has about a 1" gap where both walls came together, best i can feel is a single screw was holding the center of the stud. How much of a pain is it to remove the wall panels?
KIPKERS is offline   Reply With Quote
Old 08-05-2016, 07:17 AM   #2
Head Rambler
Are you sure the sidewall hasn't moved?
How old it the unit?
Can you post pics of the separation?
Removing the partition paneling isn't too much of a problem as it's stapled on. However, the chance of tearing it when removing it is probable. Use a flat pry bar and it'll help.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 08-05-2016, 01:39 PM   #3
Tfort's Avatar
Mine hasn't gapped. I hope it is not the outer wall.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 08-07-2016, 08:01 AM   #4
Its a 2015, and no im not sure it isn't the sidewall v the dividing wall. Ill have to try and get pictures here soon.
Old 08-07-2016, 12:59 PM   #5
I have the same year and model. A picture may help me help you. Let us know when its posted!
MOODMAN is offline   Reply With Quote
Old 08-07-2016, 03:20 PM   #6
Head Rambler
When you're taking the pictures, take one looking straight down the side from front to back or vise-versa. That may let us see if it looks bowed out.
You may want to take a straight edge and hold it against the sidewall inside and out and see if it's bowed.
Hopefully it isn't and you'll just need to resecure the stud.
Gotta go campin!
Old 08-21-2016, 01:53 PM   #7
Here are the pictures, not the best but we were in a hurry. I put a level to the side wall and it appears straight.
ID:	117993   Click image for larger version
Old 08-21-2016, 01:58 PM   #8
Head Rambler
If the wall is straight, then just reattaching the partition is probably all you need to do.
Let us know how that goes.
Gotta go campin!
Old 08-21-2016, 04:58 PM   #9
Tfort's Avatar
I would run a straight edge, maybe a 4' level on the wall and see if it is bowed out. If so and you are out of warranty, call forest river and let them know what's going on and see if they will help you out. Couldn't hurt.
Old 10-18-2016, 06:02 AM   #10
Alright, here are some updated pics, it appears the wall has separated more, and possibly starting on the other side of the slide as well now. When slides pull in the walls appear flush. A 4 foot level on the inside of exterior wall shows a gap in center of level, hard to tell on exterior.
Would forest river consider this a warranty issue although i am out?
ID:	123309   Click image for larger version
ID:	123310   Click image for larger version
ID:	123311   Click image for larger version
