Old 05-22-2016, 03:39 PM   #1
HG 365qb landing gear issue
I recently installed jt strongarms and since then the landing gear switch stopped working. Is there anot her fuse besides the ones in the door side battery conpartment? My lci linc system still works but nothing at the switch. Could the jt have caused the issue?
KIPKERS is offline   Reply With Quote
Old 05-22-2016, 08:50 PM   #2
Tfort's Avatar
I have heard there is one in line to the landing gear somewhere in the front compartment. I also understand there is a separate fuse box behind the wall in the passthrough under the stairs. I plan on verifying both soon so that I don't get myself in a bind. I have not had an issue yet so I have not verified it myself. The strongarms should not have caused it unless you forgot to loosen them and it increased the load to the point it blew the fuse.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 05-27-2016, 01:44 PM   #3
My system is located behind the rear wall in the pass thru. It has fuses that feed the different switches that are seperate from the remote function. Each of the remote functions has a fuse to that particular switch. Look on the Lippert electronics web site for diagrams and pictures.
2011 F350 Lariat Ultimate Dually 6.7 w/ B&W Companion
2014 Heritage Glen 356QBQ
2016 Explorer Platinum, 1998 Mustang
1SG(Ret) (1987) US Army Aviation
Days/Nights Camped 2016: 34
dogwood36322 is offline   Reply With Quote
Old 05-29-2016, 08:53 PM   #4
Thanks I was afraid I was going to have to talert apart the underbelly again. We leave for MI this week and I need to get the gear fixed
Old 05-30-2016, 12:15 PM   #5
Finally found the fuse, stuffed up in the wiring about midline of center front compartment, 30 amp blade fuse.
Old 05-30-2016, 07:12 PM   #6
Tfort's Avatar
Good to know. I need to locate them because it seems to be a common issue.
