Old 12-30-2015, 01:59 AM   #1
Hot & Cold water issues - switches
We just bought a brand new Wildwood X Lite 282qbxl in September 2015.
We have had a few issues that I need help in correcting.
1. HotCold water. When I use water from the tank, the hot and cold from the sink and shower work properly, but when I hook up the city water to the back of the trailer, the hot/cold get switched. Hot water comes out when I turn the cold handle and vice versus.....any thoughts on what might be the issue?
Ken
kputtman is offline   Reply With Quote
Old 12-30-2015, 06:12 AM   #2
fonzie's Avatar
The city water inlet is connected to the hot water system piping? Do you get hot water at toilet also?
Fonzie
Old 12-30-2015, 06:25 AM   #3
TURBS's Avatar
I can't wrap my head around how this is possible.
Old 12-30-2015, 07:48 AM   #4
Pickin' & Campin'
I agree. Strange!
The only possibility I could think of is if the OP was somewhere where the weather was VERY warm and the city water hose (and possibly the pedestal hook-up) was in direct contact with the sun for a long period of time and when the cold faucet was opened it would draw that very warm water into the RV and out the faucet. Of course it wouldn't last all that long and in reality hot should come out the hot side as well, not cold so I'm stumped.
Even if the CW supply was somehow plumbed into the hot water side of the plumbing I can't imagine how it would reverse the flow at EVERY faucet?
If something was amiss with the WH bypass valves it wouldn't work correctly with the pump.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 12-30-2015, 07:52 AM   #5
bubbles's Avatar
Being as how shore water and pump water are connected in parallel (at least their supposed to be) this situation just doesn't make sense.
Old 12-30-2015, 07:58 AM   #6
Head Rambler
If the city water inlet was connected to the hot water side of the plumbing it would do exactly as he described. It would reverse flow through the water heater and hot water would flow out through the cold water lines everywhere in the unit. Also cold water would flow out the hot water lines.
Gotta go campin!
Old 12-30-2015, 08:00 AM   #7
WAG, the Factory Tee from City Water is on the Hot water side of W/H and Back feeding? Youroo!!
youroo is online now   Reply With Quote
Old 12-30-2015, 08:28 AM   #8
Yes. Most likely a Suburban heater which typically do not have a check valve, unless one is installed by the RV manufacturer. An Atwood has a check valve on the outlet side of the heater that comes from Atwood as part of the heater.
That's how an Atwood can use a bypass kit with 1- 3 way valve (on the heater inlet side of the cross connection), but a suburban needs 2 -3 way valves (one at each the inlet and outlet side tie ins of the cross connection).
Mr Havercamp is offline   Reply With Quote
Old 12-30-2015, 08:41 AM   #9
Pickin' & Campin'
Yep, I can see where Bama and Havercamp are correct.
I forgot some water heaters do not have the check valve in the hot outlet.
Look for the city water supply and see if it is plumbed into the hot side of the plumbing.
Old 12-30-2015, 09:15 AM   #10
Wow - this forum is amazing! This is my 1st travel trailer, so I am speechless as to all the help and suggestion.
Couple of replies....
1. Yes, when connected to the city water, hot water flow thru the toilet, as well as every cold water side. (It is crazy).
The trailer has the blue/red pex, flex piping, so I was able to determine that it was in fact switched when on city water.
water
