Old 04-03-2017, 08:36 AM   #1
Hot water draining from cold point drain
Took the new rig out for the first time this weekend and when I was packing up I opened both low point drains. Hot water was coming out of the blue cold water drain after a few minutes. Is this normal?
dboshibby is offline   Reply With Quote
Old 04-03-2017, 08:45 AM   #2
Flybob's Avatar
It is possible that it was coming from the WH in a reverse flow. There is no back flow valve on most water heaters. What faucets did you have open. It is always a good idea to drain the WH prior to opening the ow point drains so that any debris in the WH is not sucked into the cold water line and left in there to clog toilet, faucet or shower valves when you use the system again.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-03-2017, 08:51 AM   #3
SeaDog's Avatar
X2 what Flybob said good info for all campers
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-03-2017, 09:08 AM   #4
Check the outside shower to make sure both faucets are off.
Another location to check is the WH bypass valves.
BBQGUY is offline   Reply With Quote
Old 04-03-2017, 09:20 AM   #5
wmtire's Avatar
X3. On water heaters without backflow preventers/valves.... When you remove the pressure on the lines, then there is nothing to keep the cold water pushing into the hot water heater, and thus pushing the hot water out into the hot water line.
The water in the heater tank will then backflow back into the cold water line via gravity, and thus out your cold water low point drain.
This schematic may help you visualize it better:
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 04-03-2017, 09:27 AM   #6
Herk7769's Avatar
Yes indeed.
HAM CALLSIGN - KC3FFW
drain, hot water, water
