Old 05-04-2012, 09:28 PM   #1
Tincup13's Avatar
Any suggestions on how to light gas hot water heater for first time after winter?
Tincup13 is offline   Reply With Quote
Old 05-04-2012, 09:35 PM   #2
TURBS's Avatar
Makes sure its full of water and the bypass valves are switched then turn the switch on
Old 05-04-2012, 09:35 PM   #3
Triguy's Avatar
Is this heater a DSI and its trying to light but not lighting?
If so, try bleeding the gas lines by lighting the stove top first. Also, check for spider webs or anything else blocking the gas.
What make and model water heater do you have?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-04-2012, 09:49 PM   #4
Tincup13's Avatar
Suburban. It's just hard to get lighted first time out. Hoping for a new trick. I light stove to get gas flowing just hoping for something else. Thanks
Old 05-04-2012, 09:57 PM   #5
I had a similar issue with my previous travel trailer. I blew out the gas orifice with compressed air and it solved the problem. It dosen't take much of a restriction of the gas orifice to cause issues. I have had the same problem with the gas orifice on the fridge. Compressed air has worked every time for me.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 05-04-2012, 10:20 PM   #6
Our new 5ver w/ DSI would take 5 or 6 times to light. I finally removed the burner and electrode and re-aligned the electrode to the dimensions in the manual. It now lights the first time it tries. Page 12 shows how it should be positioned. I had to tweek mine in both directions.
