Old 05-08-2014, 04:53 PM   #1
Adony's Avatar
How safe is this?
Although we love our Wildwood TT, a recent leak at the external water supply connection had me wondering just how safe the design was?? Installing the water connection directly several inches above the 30A power connection??
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 05-08-2014, 05:02 PM   #2
In my trailer, the water pump, water inlet, and literally everything else water related, is right next to the electric converter box. Super smart. Makes me want to build something around it to shield it from water in case of a leak.
TV: 2016 Ram 3500 4x4 mega cab w/6.7l Cummins
Trailer: 2013 Palomino Puma 27SBU
bitNine is offline   Reply With Quote
Old 05-08-2014, 05:07 PM   #3
jonandjolene's Avatar
Your power cord connection should be water proof if connected correctly. Would not be much different than an extended rain storm.
JonandJolene
2013 Blue Ridge 3125RT
w/ TrailAir suspension
2015 Ford F250 4X4, 6.7 PSD
Pullrite Slider Hitch
jonandjolene is offline   Reply With Quote
Old 05-08-2014, 05:08 PM   #4
X2
Old 05-08-2014, 05:09 PM   #5
markb5900's Avatar
From the pic, doesn't look to good to me. Some engineer that hasn't been out of their office in years designed it.
In my Salem, the cord is directly ABOVE the water hook up.
I would just make sure you have good hose washers in it. At least the flap should deflect most of the water from it if you do have a drip.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 05-08-2014, 05:13 PM   #6
Kaadk's Avatar
And I thought it was bad that my electrical connection was right below the fridge's condensation drain. As the other's have said it should be waterproof if properly connected. Just make sure "disconnect city water" comes before "disconnect electrical" on your closeup checklist.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 05-08-2014, 05:27 PM   #7
I would shut the power off at the pedestal first and then the water @ the faucet before I touched the camper IF I was worried.
Old 05-08-2014, 05:31 PM   #8
TURBS's Avatar
My flagstaff had the same connection.
6 years never an issue.
TURBS
Sabre owners united!
