Old 07-01-2018, 09:32 PM   #1
Denny.L's Avatar
how to I drain my freshwater tank?
We have a new 2019 Wildwood x-lite 241 RL XL.
We have had it for 1 month now,. The dealer filled up the fresh tank before we drove it off the lot.
My question is we haven't used the fresh water as we've utilized the City water connection in the two campgrounds we have been to.
My question is: How do I drain the fresh tank so this way I can put fresh water in there? that old water has to be stagnant by now.
thanks
Denny.L is offline   Reply With Quote
Old 07-01-2018, 09:47 PM   #2
There is a valve (usually near the shower, access panel, or low point of tank). You can do a You Tube search for winterizing your vehicle if someone here doesn't respond before you need to drain it. After winterizing you would need to drain everything.
briteday is offline   Reply With Quote
Old 07-01-2018, 09:50 PM   #3
Mr. Dan's Avatar
Do you know how to locate your fresh water tank?
Can you find the fresh water tank fill?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 55; booked = 20
Old 07-01-2018, 09:53 PM   #4
There should be a drain hose with a valve under the camper. Mine is in between my wheels.
scottnlindsay is offline   Reply With Quote
Old 07-01-2018, 10:20 PM   #5
Mr. Dan's Avatar
Mine has a screw on/off cap.
Old 07-01-2018, 10:44 PM   #6
asquared's Avatar
The low point drains you are looking for are underneath the trailer, usually near your hot water heater panel on the outside. You are looking for 2 lines, the red is hot, the blue is cold. It usually drains best with a tap open. You will likely have to unscrew and remove a cap. Some fresh water tanks will require a fresh water fill hoseto fill them.
If you are concerned about stagnant water you may want to sanitize the fresh water tank before refilling it.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-01-2018, 11:41 PM   #7
KeithInUpstateNY's Avatar
Both my Bullet 220RBI and my Avenger 21RB had three drain points, in different locations under the respective trailers. Two should be grouped together with either red and blue caps, or valves, depending on the trailer. These are for draining the water lines themselves. The third one, by itself, is the one you are looking for. It is for the freshwater tank. USUALLY it is in the vacinity of the fresh water fill inlet since both are connecting to the fresh water tank and manufacturers economize on materials, but it may be near the edge of the underbelly or almost smack in the middle.
Sent from my XT1254 using Tapatalk
KeithInUpstateNY is online now   Reply With Quote
Old 07-02-2018, 12:39 PM   #8
I thought the blue/red drained tank. NO. That just drains lines
The drain on my 25RL is between the left side wheels. Lucking for me on the very cold night I ran the heat. My tank after winter still show water in it.
Lucky
Bluetick1955 is offline   Reply With Quote
Old 07-02-2018, 12:53 PM   #9
Look under the trailer, the drain should be almost below where the intake is on the side. On my last Wildwood trailer, it was between the wheels and has a screw on cap.
Rita B
2016 Surveyor 201RBD
2006 Jeep Commander 5.7 Hemi
Camping
2017- 27 days
2018- 100 days
RitaB is online now   Reply With Quote
Old 07-02-2018, 01:08 PM   #10
MillMitch's Avatar
And when people say you are going to need to get under the trailer, they mean that literally. My freshwater drain was between the tires inside the frame, single white line sticking down with a screw on cap. I couldn't see it unless I was on my back. Will probably have a bunch of foam around it (my freshwater drains had foam up to the caps).
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
drain, tank, water, water tank
