Old 01-23-2015, 06:48 PM   #11
Campster's Avatar
Originally Posted by SeaHarley View Post
I understand what you are saying. As I thought the same thing.
My guess is that maybe there is some sort of ground going on through the convertor as that is connected to the same buss inside.
I'm only stating the way it is working on my trailer, I suggest you check your own.
What was happening on mine, and the way I found this out was; my propane detector started going off continuously, the red light was on instead of green. And my radio memory (blue background) light remained on. And my battery voltage was still dropping over a few days. So I put the meter across the pos. and neg. terminals inside on the panel and found what I'm calling stray voltages between 3 and 6 volts..... Go figure.
So yesterday, I finally got a chance to switch it over from the negative to the positive side. The switch is located right at the battery as I did a post on it.
Battery Cut Off / Disconnect Switch
Anyway, now, with the switch "off", there is no voltage inside and the propane detector light and radio lights are off....
Strange....? With my negative side of the battery running through the switch when I have the batteries disconnected I have no power to anything including all detectors and the radio. The whole trailer is powerless...This was the same with two previous trailer I have owned. I'm not sure where or how you got power or current to those things without battery being fully connected. Something seems off in your setup? Do you have two batteries or one? If two did you use the negative cable that was running to the frame?
Campster is offline   Reply With Quote
Old 01-23-2015, 07:07 PM   #12
SeaHarley's Avatar
I only have one battery, and one ground wire from the battery. (Although I will be adding a 2nd battery in the future.)
Like I said, I'm only stating what happened on and with my trailer. I am not an electric buff, etc. And I am not saying I am right or anybody else is wrong.....
My trailer is a 2012 and really only 2 years old.
My reason for posting this, is to point out that not all trailers are the same.
I would suggest for anyone reading this and thinking about doing it, before you do, first disconnect the ground wire from your battery and make sure that all lights, etc. are off and there is no voltage inside at the panel. If not, then you are good to go.
2012 Lacrosse, 308RES.
2013 Ford F150, XLT, 4x4, Supercrew, Eco-Boost.
Lee, Dawn and "CoCo", the dog!
2015 Overnight Camping Days = 25, States Below:
SeaHarley is offline   Reply With Quote
Old 01-23-2015, 09:18 PM   #13
josephkell's Avatar
There must be an issue with your battery, switch or something else...
josephkell is offline   Reply With Quote
Old 02-01-2015, 08:20 AM   #14
jonrjen's Avatar
I'm no electrician, but would the battery still provide a current if the neg side of the battery was off at the battery, but the item in the RV was direct grounded to the frame of the RV. Would that not complete a circuit?
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 02-01-2015, 12:43 PM   #15
Infractee
Every 12V item in an RV is direct grounded to the frame at some point, except maybe the tongue jack on a TT and the breakaway switch on a TT. (which was how mine was wired)
ONLY if the negative from the battery was still somehow connected to the frame could there be voltage beyond the two post on top of the battery.
My vote is a switch issue that is now not showing itself while connected to the positive side. (or not showing up as readily)
High voltage AC and super high voltage DC will make an air gap if close enough, 12 VDC will not.
RhoZeta is offline   Reply With Quote
Old 02-01-2015, 12:57 PM   #16
bubbles's Avatar
It is possible to pick up a high impedance ground potential thru a plastic battery box. Either thru static electricity or condensation. This was an issue with my boat a few years back. Had a disconnect on the negative side and had to move it to the positive terminal. Just my input.
Old 02-01-2015, 01:05 PM   #17
Thanks for the info.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 03-09-2015, 10:48 AM   #18
Shermanator's Avatar
Great write up, I was just in the process of doing this, thanks...Sherm
2013 T21FD Northwest Edition Wildwood
2010 Duramax Sierra SLT
Shermanator is offline   Reply With Quote
Old 03-12-2015, 09:56 AM   #19
For you Canucks, Princess Auto has the switch you see in the pics, $15.00. It also has a removable knob so no one can dick with the switch, not that I know anyone that would want to dick with my switch???????? This switch has a bottom plate that worked nicely by putting it on the inside of the battery cover to give the entire assembly a little more stability. I also bought two short lengths of battery cable and added them on, this way it makes taking the cover off and disconnecting the battery very easy. I did hook it up to the positive side, as per the instructions that came with it. Sherm
ID:	71199   Click image for larger version
ID:	71200   Click image for larger version
Old 03-12-2015, 09:59 AM   #20
(Dry Huunday)
DreiHunde's Avatar
Nice job Sherm!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
battery, battery disconnect, wildwood
