Old 01-08-2019, 09:01 PM   #1
Hybrid heat install on 261bhxl
Hi there!!! I have a new x lite 261bhxl.... Iím wanting to add the camco hybrid heat to my water heater....has anyone installed one yet?? And if so where did you find 120v power to plug into? Iím thinking of running a dedicated line from under the fridge around the tub and into the tank compartment...Thanks for any help!
Welderwill85 is offline   Reply With Quote
Old 01-08-2019, 09:12 PM   #2
I installed one about a year ago. I full time and really like not having to fill the propane tank as often. I was lucky as my water heater is under one of my benches for kitchen table and there was a 120 outlet on wall under the table. I was able to drill a small 1/2Ē hole in metal shroud front on water heater inside the cover and run wires inside where I was able to just plug it into outlet. I also installed a on/off switch with red light at the outlet to see if I have it on or off. Easy install really, Mabee took me all of a hour at the most.
Decon Blue is offline   Reply With Quote
hybrid
