Old 02-11-2012, 07:59 PM   #1
inverter for wildwood 19'
I need to change out inverter ...have misplaced owners manual. Does anyone know what size to buy?
wonderingvolunteer is offline   Reply With Quote
Old 02-11-2012, 09:25 PM   #2
TURBS's Avatar
Don't you mean converter? An invertor takes 12 volts and turns it into 110 . A converter takes 110 volts and turns it into 12 v
All the specs you need are on the converter you currently have.
If your not sure if you have an invertor or converter you may want to have someone that has replaced one before do it for you.
Don't get me wrong but I just want to make sure you know what Ur doing.
Whats wrong with your current one?
Old 02-11-2012, 10:54 PM   #3
Assuming you mean the converter, open the cover, read the manufacturer and model number on the label, and check their website, or post back here with the name and numbers. You gave us trailer, but not year, and not all trailers all equal, based on options.
I'll also ask, why do you need to change it? What problem do you have?
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
