Old 09-12-2016, 10:17 AM   #1
nuisance's Avatar
It's Shocking!!!!!
A friend just bought used a 03 wildwood 30'bhss and everytime he touches the unit exterior he gets a shock. HELP!!! What should he look for to fix this. Ow does someone have a number that he can call for help?
Deb and Phil
Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
Old 09-12-2016, 10:26 AM   #2
Iwannacamp's Avatar
bad ground somewhere.... is it full voltage or a trickle? If it is 120V AC I would look hard at any outside outlets. You might can un-plug the shore power and OHM each terminal to frame ground. This will tell you if there is a short. If all or most of this is "greek" then he/she should call someone. IMO
2017 Puma 297RLSS
Old 09-12-2016, 10:35 AM   #3
Always Learning
RV Electrical Safety: Part IV – Hot Skin | No~Shock~Zone
Old 09-12-2016, 10:39 AM   #4
RV Hot Skin.
Read the above link and that'll tell you what the problem is. Basically there is no ground on the Rv and the hot & neutral are swapped.
Gotta go campin!
Old 09-12-2016, 10:39 AM   #5
wmtire's Avatar
Mike Sokol is the de facto expert on this situation:
We keep a sticky from Mike about this here, which your friends problem is most likely a bad ground somewhere as has been pointed out.
http://www.forestriverforums.com/for...-rv-89191.html
2011 Flagstaff 831 RLBSS
