Old 06-02-2018, 07:57 PM   #1
Jack Size
What size jack does everyone use to change a tire on their camper if the max weight is 7,000 pounds? Thanks so much for any and all advice!!!
plh869 is offline   Reply With Quote
Old 06-02-2018, 08:21 PM   #2
Blackrock's Avatar
I've been carrying a Walker 3 1/2 ton bottle jack that I've had for over 30 years. That and some blocking and a good breaker bar and deep socket has done the trick on all my rigs through the years.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 06-02-2018, 11:19 PM   #3
What do you mean by blocking? Thanks!!
Old 06-02-2018, 11:30 PM   #4
Are you putting blocks of wood under the jack and on top? My husband is asking. Thanks so much!!!!
Old 06-02-2018, 11:34 PM   #5
SailorSam20500's Avatar
Jack the trailer up and put something solid for the frame to sit on. Cement blocks, timbers, etc. Just make sure it is strong enough to hold the weight and stable so it doesn't shift.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 06-02-2018, 11:36 PM   #6
What size and type jack do you use? Our camper is 7,000 pounds. Thanks!!!
Old 06-03-2018, 07:01 AM   #7
Head Rambler
I use a 12 ton hydraulic bottle jack. Mostly because I already had it. If I were to buy a new one, I'd buy a 6 ton model, just because it's a little lighter.
You may need to buy a low profile jack. Measure the distance from the frame to the ground on the camper and subtract the height of the tire sidewall and buy a jack a little less than that height. That'll ensure that it'll fit under the frame when the tire is flat.
I also take a pair of 2 ton aluminum jack stands with me. They are lighter and smaller than any cribbing or blocking that I could carry.
Gotta go campin!
