Old 10-12-2017, 09:43 PM   #1
LED lights
We just bought a brand new Wildwood X-light and I cannot for the life of me figure out how to turn on the LED lights. When I turn on the switch in the camper, all they do is flash different colors. The remote doesnít work at all. I just want plain white non-blinking lights. Thanks in advance.
cutigerjd is offline   Reply With Quote
Old 10-12-2017, 09:58 PM   #2
rsdata's Avatar
Is the remote like about 1.5 inches by 2.5 inches? The reason I ask is that several LED light strips I have fooled with they all come with almost the same controller. Once you setup the lights to do whatever, flash, be GREEN, or RED... when you turn them off with the camper light switch, then when you next turn them on they go right back to where they were when they were turned off.
Often on NEW controllers, there is a small plastic strip near the battery pack opening that must be removed before the controller will work...
OR, are you outside pointing the remote at the LED strip? Becuse usuallly the controller of the LED light strip is located at the beginning of the LED strip and you have to point the remote at the controller...
hope this helps
ďToo much of anything is bad, but too much good whiskey is barely enough.Ē Ė Mark Twain
2014 Shamrock 183
Old 10-12-2017, 10:15 PM   #3
Same with me. All they do is flash. I pulled the plastic out and checked the battery. Nothing but flashing lights.
Old 10-13-2017, 06:28 AM   #4
PoPo Cliff's Avatar
Hope this helps.
RGBW LED Controller
2017 Flagstaff 26RLWS
PoPo Cliff is offline   Reply With Quote
Old 10-13-2017, 07:16 AM   #5
When I see multi color flashing lights...I always have flashbacks to Silk shirts, Platform shoes. Bell bottoms, and then I go into my Saturday Night Fever routine.
TheWolfPaq82 is offline   Reply With Quote
Old 10-20-2017, 02:16 PM   #6
J-Belew's Avatar
There is a sensor near the end of your awning. Look for a couple wires that stick out and point your remote at it. I had the same issue. Now my issue is what color to go with.
J-Belew is offline   Reply With Quote
led, light
