Old 09-09-2019, 07:10 AM   #1
LED Lights Under Awning Remote
Lights under awning come on with the inside switch and are red, green and white in color. Can't get the RGBW remote controller to work with them like they are supposed. Put in a new battery but no good. You supposedly can change the color, make them fade in/out, etc. Dealer has no clue of course.
Mike
Mike Gray
Forest River Wildwood
2018 230BHXL
2015 Sierra SLE 5.3 V8 4x4
Mike223 is offline   Reply With Quote
Old 09-09-2019, 07:31 AM   #2
Flybob's Avatar
Try turning them off with the inside switch then turn them on with the remote and try again. In some units, the two switches are connected in parallel and if turned on with the inside switch the remote may not function properly.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-09-2019, 08:46 AM   #3
I uncovered the remote controller that was behind a wall plate inside the tt and pulled and pushed until it started working???
Mike
Mike Gray
2018 230BHXL
led, light, remote
