Originally Posted by zapme01
I have used both lego blocks and wood. I just purchased the Anderson wedge and I must say it is a lot easier with the wedge. One time and your done. It also acts as a wheel chock when your done leveling.
Call me crazy but I am still skeptical on the wedge for a two axle trailer. If you can only get one wedge in due to the tires being too close then you are effectively *partially* lifting that side of camper up on only one tire, increasing the load on that tire and decreasing it on the other. Would seem to me that it would add to instability at the least and possible tire overloading at the worst.
I will stick to my PT 1X6, each piece goes under both tires, as solid as if on pavement.
