Old 08-03-2014, 09:57 AM   #1
Leveling scissor jacks
I have a new 2015 wildwood and have the automatic scissor stabilizing jacks. With older hand cranks you can make your trailer level. I have tried adding blocks under the side that needs to be raised but as soon as the jacks feel pressure they stop. So they done level like standard jacks. How do I keep the trailer level?
tilq is offline   Reply With Quote
Old 08-03-2014, 10:04 AM   #2
Plain Old Member
Those scissor jacks are stabilizers only. They are not intended to level the trailer. Level by using boards or blocks under tires for side to side, then tongue jack for front to back, then the stabilizers just snug against the ground. Using any stabilizer jacks for leveling can cause major issues or damage. Doors won't open, slide outs won't work etc etc.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 08-03-2014, 10:05 AM   #3
Ford Idaho's Avatar
Are you placing the blocks under the tires or the jacks?
Old 08-03-2014, 01:31 PM   #4
Engineer of Crazy Train
ChooChooMan74's Avatar
x3 on the jacks being STABILIZER jacks. They are not intended to lift or level the camper. As others said, level the trailer using boards, legos, andersen levelers, etc. Then use the stab jacks to limit the rocking.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 08-03-2014, 02:01 PM   #5
asquared's Avatar
This is correct.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 08-04-2014, 04:31 PM   #6
Just bought the Andersen Camper Levelers. I'll be level next time around. That was only the second time out with the camper so were getting the bugs out. Thanks all.
Old 08-04-2014, 04:48 PM   #7
Ford Idaho's Avatar
No worries.
Out of curiosity what are you using for a level?
Old 08-04-2014, 06:06 PM   #8
Originally Posted by Ford Idaho View Post
No worries.
Just a standard 12
inch speed level
Old 08-04-2014, 06:13 PM   #9
sammonilla's Avatar
Like others have said, Blocks of wood under the tires and the toung jack to level before you open doos and the slide outs. I also have the stablizers and I run them down with power and use the hand crank to snug them up a little. It will help stop the TT from swaying while you are walking around. I also use a TWO way level that I mounted to the tounge of the TT so it is easy to see if I am Level. One last thing, I usally set the level so I am just a little high on the slide out side as the weight of the slide pulls it down just a bit!
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2016 SILVERADO 2500HD 6.6 Duramax
2012 280BH Casscade
sammonilla is offline   Reply With Quote
Old 08-04-2014, 06:19 PM   #10
Ford Idaho's Avatar
Originally Posted by tilq View Post
Just a standard 12
inch speed level
Ah.
jacks, leveling
