06-08-2016, 10:41 AM
Lippert remote won't operate inside lights, 2015 Heritage Glen
I Have a 2015 Heritage Glen 356QB 5th wheel that has the Lippert remote pad. Does anyone know if this pad is suppose to operate the inside lights as well. It operates the awning and the awning light and landing gear along with the rear stablizers but didnt know if its suppose to operate the inside lights as well.
06-08-2016, 12:17 PM
I go RV'ing not Camping
It does not operate the inside lights unfortunately
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
06-08-2016, 12:43 PM
Do you know if you have the 5 function or the 8 function receiver?
Also does it operate the slide(s)?
Gotta go campin!
06-08-2016, 02:19 PM
Mine operates the slides, but I have the lincpad.
06-09-2016, 08:23 AM
Ours operated awning light, awning and landing gear only
Marty, Carla, Gabby and our ankle biters Rocky and Addy
2011 Dodge Ram 1500 SLT Big Horn 4x4 Hemi 5.7
Forest River Wildwood 30KQBSS
06-09-2016, 10:08 AM
Some of the remotes operate both slides, the awning, awning light, stabilizers and landing gear. those have 8-function receivers and a couple of the functions aren't used. A handy knowledgeable person could add the interior lights to it if they were so inclined.
Gotta go campin!
06-10-2016, 11:35 AM
I think its a five function. It operates the awning, awning light, rear stablelizers, landing gear and slide outs.
06-10-2016, 11:38 AM
This is all new to me. Hope you got my last response.
06-10-2016, 11:47 AM
hmmmm....this sounds interesting
Would you happen to know such a person??
06-10-2016, 11:52 AM
The only way to be sure which receiver you have is to physically look at it.
If both your slides operate at the same time, then it could be a 5-function, if they operate separately then it's an 8-function with one function not used.
Gotta go campin!
06-10-2016, 11:57 AM
I have the lincpad with the app. Each of my slides operate separately and my front and back stabilizers are seperate and then I have awning in/out and awning lights so that is 6 functions.
It also does have a section in the app for lights, but of course it doesn't work cause it's not hooked up.
It also has a place to check the tank levels, which I thought would also be pretty good to have on the tablet, I just wasn't sure how to hook it up, if I needed a relay or something from Lippert?
06-10-2016, 11:58 AM
I might know somebody!
The hardest part is getting the remote reprogrammed. You may get lucky and it may already be programmed and you just need to turn the function on. Then you'd need to wire from the light switch to the receiver.
There are wiring diagrams on the internet that show how they recommend wiring them. You can also find programming instructions.
You just need to know which generation you have.
Gotta go campin!
06-10-2016, 12:05 PM
If you press the Lights button in the app, do you hear a relay in the receiver click?
Since you already have the lights section turned on, all you need to do is get wiring from the lights to the receiver. The easiest place to do that is at the manual switch in the panel.
Gotta go campin!
06-10-2016, 12:07 PM
Thanks for the heads up, I will poke around for the diagrams from lippert. I think I remember reading somewhere how to program the lincpad so I will have to find that again and take it from there
06-16-2016, 02:19 AM
We own a 337BAR, our remote only controls slides/awning/awning lights/front landing and rear stabilizers. I would say we have the same remote and receiver... sucks but hey we still have awesome trailers.
Enjoy it!
06-16-2016, 08:09 AM
I can operate the 4 slide outs seperately. So I guess it's an 8 function.
06-16-2016, 12:00 PM
Yep, if they're separate buttons then it's an eight function receiver.
Gotta go campin!
