Old 10-10-2016, 02:47 PM   #1
Low point drains
I have. 2012 Wildwood 32ft BHSS
I only found one low point drain hose - the blue coloured one
I can't find the red one anywhere
Should I not have both a red one and a blue one ?
Could the hot water one be in a completely different place than the blue one ?
Tmauro is offline   Reply With Quote
Old 10-10-2016, 03:56 PM   #2
Perhaps your hot water heater is the low point?
Skyliner is offline   Reply With Quote
Old 10-10-2016, 04:08 PM   #3
bubbles's Avatar
I only have one low point drain and if the winterization valves at the water heater are set to by-pass the water heater it will drain both hot and cold water lines.
Old 10-11-2016, 12:30 PM   #4
Forest River is either lazy or incompetent for this topic.
They put my drains on top of the galley gray water tank. You have to literally climb under the camper and stick your arms up between the tank and the frame to reach them.
It is unbelievable that they are too cheap to put an extra 8 inches of tubing on the drain line to at least get it even with the bottom of the tank.
mkosu04 is offline   Reply With Quote
drain
